63
No LED Notification light on 6T
Does Notification LED matters to you?
  1. Yes
  2. No
Results are only viewable after voting.
  1. sweggitity
    Ice Cream Sandwich Dec 4, 2018
    sweggitity , Dec 4, 2018 :
    u should have done your research
  2. Aspidex
    Gingerbread Dec 4, 2018
    Aspidex , Dec 4, 2018 :
    Yes I know
  3. Ajnasz
    Cupcake Dec 4, 2018
    Ajnasz , Dec 4, 2018 :
    Thanks for removing the LED, finally I don't pick up my phone for every notification. They just not important.
  4. Adiker
    Froyo Dec 4, 2018
  5. sweggitity
    not good enough,will consume a lot of battery
  6. Adiker
    Froyo Dec 4, 2018
    Adiker , Dec 4, 2018 :
    Not really, maybe it will be worse but definitely not a lot. You can also change interval if you like.
  7. DrJMun
    KitKat Dec 4, 2018
    DrJMun , Dec 4, 2018 :
    I ALMOST pulled the trigger on buying a 6T, fortunately I read in the forum that it does not have an LED notification light. I could live without headphone jack but I need LED.
    tebsoo likes this.
  8. Adiker
    Froyo Dec 4, 2018
    Since there is something like Pixel Pulse, you can use that instead.
  9. felipemendes
    Jelly Bean Dec 4, 2018
    felipemendes , Dec 4, 2018 :
    I think I used a led (and have not been annoyed by it) last... never.
    It's liberating not to know what's going on with the phone when it is away from you.
  10. sweggitity
    Ice Cream Sandwich Dec 5, 2018
    sweggitity , Dec 5, 2018 :
    It isn't good enough. OnePlus needs to implement it in their system
  11. guisbro
    guisbro , Dec 5, 2018 :
    What's not good enough? I never bothered with the LED notification on my OPX, but Pixel Pulse gives a useful notification that I actually use. Thanks for getting rid of LED OP as I wouldn't have found Pixel Pulse if you hadn't!
  12. guisbro
    It doesn't have any noticeable battery use over 48 hours.
  13. E1543350617166
    Cupcake Dec 5, 2018
  14. Adiker
    Froyo Dec 5, 2018
    Adiker , Dec 5, 2018 :
    You have mod to AOD on XDA. However it uses too much battery, so it's not recommended to use.
  15. guisbro
  16. sweggitity
    the thing is, OnePlus could easily implement an on display led notification
    E1543350617166 likes this.
  17. Aspidex
    Gingerbread Dec 5, 2018
    Aspidex , Dec 5, 2018 :
    I think so too
  18. guisbro
    I'd always go for an independent developer. Faster communication link to report and get issues sorted.
  19. E1543350617166
    Cupcake Dec 5, 2018
    E1543350617166 , Dec 5, 2018 :
    Yeah, there are apps that does this already, but those replaces the entire ambient screen.
    Oneplus could easily make an update.
  20. sweggitity
    other apps that does this, doesn't allow the phone to sleep. it keeps running in the background
