63
No LED Notification light on 6T
Does Notification LED matters to you?
  1. Yes
  2. No
Results are only viewable after voting.
  1. DaRTHYiGiT Cupcake Oct 30, 2018
    DaRTHYiGiT, Oct 30, 2018 :
    Headphone jack is not necessary. Because there is bluetooth option or with cable you can use your headphone.
    I can also accept "not Stereo Speakers" because this phone is cheap bla bla...
    but only and only without notification led... i wont buy this phone. I dont wanna use "always screen on" etc. because that kind of specs are draining battery. And also Im using 5 different colors(May be more) and my phone is Sony Z3C 5 years old. im looking my led color than decice to open my phone or not.
    And I was expecting more from OnePlus because everyone praises OnePlus and i though its a good Company and listen Community...
    Just trash. I guess i will buy Mate 20 (not Pro). If i wait 1 more month price will be less than 800€
    #81
    tebsoo likes this.
  2. riffraff81 KitKat Oct 30, 2018
    riffraff81, Oct 30, 2018 :
    ...for YOU.
    #82
  3. sweggitity Honeycomb Oct 30, 2018
    sweggitity, Oct 30, 2018 :
    gotta wait and see.
    #83
  4. Deactivated User Oct 30, 2018
    #84
  5. riffraff81 KitKat Oct 30, 2018
    you have no evidence for this statement.
    #85
  6. Deactivated User Oct 30, 2018
    #86
  7. sweggitity Honeycomb Oct 30, 2018
    Yes I agree with you. Lot of phones will full to full bezelless display, even Samsung has started working on in display camera, so the future is probable. OnePlus needs a way to implement the notification LED inside the AMOLED display. It is possible, but now it is up to us community for OnePlus to listen and implement this feature.
    #87
  8. Deactivated User Oct 30, 2018
    #88
  9. DaRTHYiGiT Cupcake Oct 30, 2018
    It is just little led. Actually so easy to implement small led. I checked Mate 20 and its too small but still there. Should not be to hard. Anyway i guess i will pass this phone. I was thinking on 2 phones mate 20 or T6
    the winner is mate20.
    or may be as you said : they can use some pixels for notification
    #89
  10. riffraff81 KitKat Oct 30, 2018
    same as everyone else. it's part of being a consumer...or at least one with a brain.
    those who purchase devices with all those features you mentioned are settling with an $800-$1000 pricetag.
    works both ways.
    #90
  11. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Oct 30, 2018
    #91
  12. DaRTHYiGiT Cupcake Oct 30, 2018
    that means your phone is on your hand nonstop. at home im not even touch my phone. At work im looking only the light color. I can not play my phone every single time.
    #92
  13. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Oct 30, 2018
    KeepTransisting, Oct 30, 2018 :
    That doesn't mean it's in my hand nonstop. It just means I have no problem tilting up my phone to see updates.
    #93
  14. DaRTHYiGiT Cupcake Oct 30, 2018
    Simple question : You received a something. How do you know where did it come ? Without look or open your screen ? If you know something about that, please share :)
    #94
  15. E1540372079963 Cupcake Oct 30, 2018
    E1540372079963, Oct 30, 2018 :
    Its acceptable. No need of headphone jack or notification light..but needed big battery and double speaker..I was also waiting for OP 6T but only for IP68 Rating ..and when I understand that it's not in there and both OP6 and OP6T are similar in sd 845, camera, ram and storage. Than why pay 10k extra. I just bought OP6-8gb/256gb model in Rs. 35099,which save my 10k..and I m just loving it..it's super fast.."THE SPEED I NEED" and will surely upgrade near future with next OP 10 or OP note[e]1f609[/e][e]1f44d[/e]
    #95
  16. riffraff81 KitKat Oct 30, 2018
    he just explained that he doesn't mind tilting his phone up to see notifications, which is what ambient display allows you to do.
    #96
  17. riffraff81 KitKat Oct 30, 2018
    oneplus doesn't make the T model expecting those with the same year regular model to upgrade.
    #97
  18. OneplusExtreme Froyo Oct 30, 2018
    OneplusExtreme, Oct 30, 2018 :
    It is a bumber that there is no LED notification light on the 6T, but i'm still gonna get it because of custom rom support and dat 3700 mAh battery. But Oneplus could do a software alternative if we complain about it more
    #98
  19. sweggitity Honeycomb Oct 30, 2018
    Well, to most users it is important, i don't have to wake my phone from sleep just to see a notification, the LED helps me to know if there is a notification
    #99
    tebsoo and denniskarlsson like this.
  20. Topper_Gas Jelly Bean Oct 30, 2018
    Topper_Gas, Oct 30, 2018 :
    Simple answer: If you have received something you can check what it is if you haven't received anything you don't need to check your phone? Plus the LED also warns you if the battery is getting low and also when it's charging/charged.
    tebsoo likes this.
