36
No longer waiting for T-Mobile updates!
  1. Bombeev
    Gingerbread Dec 6, 2018
  2. JuAnCaStRoP
    JuAnCaStRoP , Dec 6, 2018 :
    Jajajajaja very funny bro!
    Bombeev likes this.
  3. Alec_Lightwood
    Froyo Dec 7, 2018
    Alec_Lightwood , Dec 7, 2018 :
    Good news. did a local upgrade (needed to use the full ROM not OTA file) and I'm now smoothy running 9.0.7
    Bombeev likes this.
  4. micjay22
    Cupcake Dec 7, 2018
    micjay22 , Dec 7, 2018 :
    Where do you download the full ROM from?
  5. Alec_Lightwood
    Froyo Dec 7, 2018
  6. micjay22
    Cupcake Dec 7, 2018
  7. Alec_Lightwood
    Froyo Dec 7, 2018
    I'm not rooted. From what I've read around the internet I think I does work not 100% on that. Unfortunately we won't get the OTA updates but as they come out we just have to flash locally.
  8. micjay22
    Cupcake Dec 7, 2018
    When you say flashing locally, you mean use the ADB method right? I get confused with browsing to the local storage location on the phone to find the ROM that you put in there beforehand in order to flash.
  9. Alec_Lightwood
    Froyo Dec 7, 2018
    Once you download you have to move it to the root of your storage. Then go to System updates and install manually.
  10. micjay22
    Cupcake Dec 7, 2018
    Alec_Lightwood
    Cool, that's pretty simple, but I don't see this option to install manually, probably enabled after flashing, so how do you do it the first time? You went straight to the full 9.0.7 ROM from T-Mo's stock ROM? The steps before the flashing step are:
    Unlock the phone from T-Mobile
    Request a bootloader unlock token from OnePlus
    Unlock your bootloader
    Is that all?
  11. Alec_Lightwood
    Froyo Dec 7, 2018
    After you unlock the bootloader put it in fastboot and flash the file in the original post (all instructions there). then copy the full ROM to the root of your storage and flash.
  12. mnchuu21
    Cupcake Dec 7, 2018
    mnchuu21 , Dec 7, 2018 :
    after the flash, do you have available 2 SIMs or just 1?
    because the difference between TMobile OP and OP Stock is the dual SIM.
  13. Alec_Lightwood
    Froyo Dec 7, 2018
    That I am not sure of. I've seen it works for some people
  14. JuAnCaStRoP
    Gingerbread Dec 7, 2018
  15. Alec_Lightwood
    Froyo Dec 8, 2018
    Alec_Lightwood , Dec 8, 2018 :
    To be honest , I couldn't get them to unlock mine either. No matter what I made up I kept getting pushed the 40 days nonsense. Ended up just paying someone to do it.
  16. fscargill
    Cupcake Dec 8, 2018
  17. JuAnCaStRoP
    Gingerbread Dec 8, 2018
    JuAnCaStRoP , Dec 8, 2018 :
    Do you know how to flash Oxygen OS
  18. fscargill
    Cupcake Dec 8, 2018
    fscargill , Dec 8, 2018 :
    I'm sure I can figure it out. I've done it with other devices in the past.
    JuAnCaStRoP likes this.
  19. Pun1sher
    Froyo Dec 13, 2018
    Pun1sher , Dec 13, 2018 :
    I can't get into fastboot mode on the phone? So the other option is the computer?
  20. Alec_Lightwood
    Froyo Dec 14, 2018
    Alec_Lightwood , Dec 14, 2018 :
    Have to hold Volume down and power
