No MOBILE DATA on 5.1.1 builds; also NO MUSIC (audio) on AK Kernel
  1. bayani
    Eclair Oct 7, 2015
    bayani , Oct 7, 2015 :
    hi, i started flashing roms because i wasn't satisfied with the 4hrs SOT and was curious about others saying other roms performed better (battery wise) so i tried Sultan's and Exodus' ROMS but there is something wrong with the mobile data. there's signal but no data incoming. all i see is H+ sign (no LTE in our place). but when i flashed COS12.1 back, mobile data was OK again.
    also, i flashed the latest AK kernel (for the battery improvements) and found that it muted by music apps.
    are there any ways to fix these?
    i dont wanna uses CO12.1 anymore and would like to try other roms/kernels but problems like theses makes me go back to COS12.1. HELP
  2. rondog648
    Gingerbread Oct 7, 2015
    rondog648 , Oct 7, 2015 :
    When on COS12.1 go into apn settings and find the one you are using and copy your apn settings then flash back to sultans rom and delete all the apn's then make a new apn using your settings from cos12.1 and see what happens.
    I just read your post again and saw that you do have H+ which is 3G so make sure your preferred network is set to LTE.
  3. leonlah
    Cupcake Oct 8, 2015
    leonlah , Oct 8, 2015 :
    Hi there!
    I am encountering the same problem! After AK kernel my audio have been muted but YouTube still works so its a bit weird on that part. Hope someone could help with this problem!
  4. rimkidikan
    Cupcake Oct 8, 2015
  5. Deactivated User
    Oct 8, 2015
  6. bayani
    Eclair Oct 20, 2015
    bayani , Oct 20, 2015 :
    3 days??? how the...
  7. Dr. Indest
    Lollipop Oct 20, 2015
    Dr. Indest , Oct 20, 2015 :
    AK is built for CM, not COS.
    About 2 weeks ago, CM made some changes to the audio system. COS is older than 2 weeks. Therefore there is a special build for ppl on COS.
  8. Dr. Indest
    forum.xda-developers.com/showpost.php?p=63245951&postcount=20200
