4
No option of Deep Clear in Android 10 Oneplus 7 pro
  1. rashils
    Cupcake Sep 27, 2019
    rashils , Sep 27, 2019 :
    I am not able to find an option to Deep Clear my recent apps in latest update of Android 10 on Oneplus 7 pro.
    I was very fond of that option as it used to stop unwanted backgrounds processes which used to help me in saving battery.
  2. G_Aseed_Usmani_rKaF
    Donut Oct 21, 2019
  3. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Oct 21, 2019
    KeepTransisting , Oct 21, 2019 :
    They got rid of it because deep clear is a bad idea and, believe it or not, can actually make battery worse because many apps would just relaunch themselves in the background.
  4. G_Sohan_Ray_
    Eclair Nov 1, 2019
    G_Sohan_Ray_ , Nov 1, 2019 :
    Actually deep clear is present in Android 10 by default. If you want apps to get deep cleared from recents panel then go to battery optimization then for the apps you want to deep clear every time just select optimize option from the three available options for the app. It would be selected as intelligent control by default. After doing that if you clear those apps from recents view they will be deep cleared.
