NO OS installed
  1. lukemantini
    Gingerbread May 29, 2016
    lukemantini , May 29, 2016 :
    Hello, All
    I have the OnePlusOne and I deleted the OS - because it was rooted. I forgot how to install another OS again, but I would like someone to contact me or Skype message the instructions for this process.
    Much help will be appreciated.
  2. itsbhanusharma
    Ice Cream Sandwich May 29, 2016
    itsbhanusharma , May 29, 2016 :
    Able to access the Recovery?
  3. pablofg1978
    Head Moderator Head Moderator May 29, 2016
  4. lukemantini
  5. itsbhanusharma
    Simply Download and Flash the OS again.
    Won't be a Real Big deal.
    You can use both fastboot & Recovery to reflash it.
  6. lukemantini
    How
  7. itsbhanusharma
    Its OPO right?
    Visit https://cyngn.com/support and download the fastboot image for OPO to Your PC
    Flash it using ADB's Fastboot command.
    Or if You can access Phone as mass storage on Your PC,
    Normally download the ZIP (Not the Dev or Fastboot)
    Copy that to the Root of Your phone's storage
    Enter Recovery, Go to Install zip from Internal Storage
    Browse the Zip You copied and wait for it
    Then simply wipe Data & Cache & Dalvik Cache
    You're done
    Now You can reboot into OS. normally
