4
no ring sound on incoming call
  1. Shaswat911
    Donut Apr 3, 2017
    Shaswat911 , Apr 3, 2017 :
    I have face some problem when some one call on my phone it only vibrate while my phone is general profile and don't know why, until I tried calling my phone and it only vibrates. I went in the sound setting then phone ringtone to select different ones but there is no sound on while one call.
  2. G_Avee_B_Xaxb
    Jelly Bean Apr 3, 2017
    G_Avee_B_Xaxb , Apr 3, 2017 :
    same here, u can restart ur fon then it works as normal again but after some time it will occur again atleast on my 3t. so annoying
    Jainchirantan and raman0424 like this.
  3. Kiran.a.joseph
    Kiran.a.joseph , Apr 3, 2017 :
    Did you try changing the ringtone to a different sound file to see if the issue still exists
  4. Shaswat911
    Donut Apr 3, 2017
  5. fede_9118
    Cupcake Apr 3, 2017
    raman0424 likes this.
  6. CAGIRISH
    Eclair Apr 3, 2017
  7. Shaswat911
    Donut Apr 3, 2017
  8. G_Avee_B_Xaxb
    Jelly Bean Apr 4, 2017
    G_Avee_B_Xaxb , Apr 4, 2017 :
    yes, i did try to change another ringtone but even the chosen ringtone doesnt give a preview sound. i tried to change sound profile back and forth from general profile, do not disturb and silent but failed. it's not just me, ive seen similar post in this forum.
  9. Sampath_Kumar_
    Honeycomb Apr 4, 2017
  10. Shaswat911
    Donut Apr 4, 2017
  11. G_ahmed_atef_nQrf
    Cupcake Apr 13, 2017
  12. G_Venkatraman_Chandrasek
    Cupcake Jan 7, 2018
  13. F_Simon_Nijland_Xhwr
    Cupcake Feb 2, 2018
  14. venunk
    Cupcake Feb 15, 2018
    venunk , Feb 15, 2018 :
    Same here, even after so many updates (i am on beta), i am still facing the same problem.....rings for few times and then goes silent. Only option is to restart and the same thing happens, rings for few times and goes silent.....
    Device - OP3T
    OS - OP3T_O2_OPEN22
  15. G_Virender_Kumar_mepl
    Froyo Feb 15, 2018
  16. raman0424
    Gingerbread Feb 15, 2018
    raman0424 , Feb 15, 2018 :
    same issue... so sound while incoming call and even on notification...
    im also on beta 22
    3t
    restarting device is temporary fix but when you slide the slider to vibration mode and then again to normal mode.....
    This Issue Continued
    G_Virender_Kumar_mepl likes this.
  17. Silviu094
  18. Y1513793110284
    Eclair Feb 15, 2018
  19. V1517638765075
  20. BasteKR
    Cupcake Feb 21, 2018
