No Ringtone sounds for phone dialer via OnePlus 7 Pro
  1. Prudhvikondreddi , via OnePlus 7 Pro , Oct 23, 2021 :
    After the update to latest update , my phone has lost its phone dialer ringtone , but speakers are working fine with all the other apps ringtones , NO silly mistakes made like slider misplacement , hope they fix it soon , Because the basic function of the phone is not working.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 23, 2021
    Dresa91 , Oct 23, 2021 :
    Can you change the ringtone?
  3. Prudhvikondreddi , via OnePlus 7 Pro , Oct 23, 2021 :
    Yes, I tried every system ringtones , But no use and I contacted customer support and shared recorded system logs , they said they are working on it , and fix it with the next update, 1 month passed problem not resolved . still waiting
  4. Dresa91
    Well, OnePlus provides updates bi-monthly.
    did you try reflashing the current os version?
  5. Prudhvikondreddi , via OnePlus 7 Pro , Oct 23, 2021 :
    I don't know how to do that , but customer support suggest to backup and factory reset . But main problem is I used to live in another country before COVID , which means I have my bank accounts and other online accounts are linked with that countries phone number , which is not working in the country which I am in now , so I can't get any OTP to log back in , so I don't want to mess it up
  6. Dresa91
    You can just download the latest zip from https://www.oneplus.in/support/softwareupgrade/details?code=PM1574162297465 and do a local upgrade
    Artemus likes this.
  7. #7
  8. Dresa91
    No, you shouldn’t:)
    Artemus likes this.
  9. Prudhvikondreddi , via OnePlus 7 Pro , Oct 23, 2021 :
    My phone OnePlus 7 pro is running eu version on oxygen os , and the link is of OnePlus 7t pro India version ,
    But Is it ok? to make a local update of software from eu to India version for OnePlus 7 pro
  10. Dresa91
    Oh sorry.
    Try the Oxygen Updater app then
    Artemus likes this.
  11. #11
  12. Dresa91
    What OxygenOS version are you using?
    Artemus likes this.
  13. #13
  14. Dresa91
    Can you please change the settings in the OxygenOS Updater App to stable and full zip?
    Artemus likes this.
  15. #15
  16. Dresa91
  17. #17
  18. Dresa91
  19. #19
  20. Dresa91
    No,…
    Only if you rollback or factory reset the phone
    Prudhvikondreddi likes this.
