No ringtone
  1. kishore_fi
    Eclair Mar 31, 2016
    kishore_fi , Mar 31, 2016 :
    hi everyone
    After i update my OP2 to MM community build i am facing some problem.... i am nt able to here any sound or ringtone when i get a call.... wat sort of problem is this
    Edit
    1) now facing slow charging... it takes around 5hrs to charge from 0% to 100%.
    2) my phone heats up a lot
    anybody facing these problems plz help
  2. mathewthomas84
    Froyo Apr 1, 2016
    mathewthomas84 , Apr 1, 2016 :
    I have the same issue post Oxygen OS 3.0 dirty flash using stock recovery.. any help anybody.
  3. mathewthomas84
    Froyo Apr 1, 2016
    Solution worked for me:
    Cleared cache from Recover, reboot, issue resolved for me.
  4. j_jona
    Cupcake May 30, 2016
    j_jona , May 30, 2016 :
    I just started using OnePlus 2 and using Oxygen 3.0.1 but there is no sound when I get a call. The ring volume is stuck at zero (and even when I finally manage to move it it goes back to zero). I tried rebooting but it doesn't work. I also erased the whole data and reinstalled everything but without any success. Can some one give me clear instructions on what to do?
  5. Robson
    KitKat May 30, 2016
    Robson , May 30, 2016 :
    Check the button on the left side of the phone. Is it all the way down?
  6. saidharshan
    Cupcake Jul 12, 2016
  7. siversails
  8. harsh211089
    Cupcake Jan 9, 2017
  9. yanirsaada12
    Cupcake Jan 9, 2017
  10. F_Sathish_Chandra_Tej_Mu
    Donut Mar 27, 2017
  11. G_Chris_Murphy_ymNT
    Eclair Mar 30, 2017
    G_Chris_Murphy_ymNT , Mar 30, 2017 :
    there have been other posts on this if you do not like the update downgrade to a previous os
