9
No Ringtones and Notification Sound. via OnePlus 7
  1. krdkoushik
    Eclair Oct 11, 2019
    krdkoushik , via OnePlus 7 , Oct 11, 2019 :
    It's been happening over and over again. I'm in oxygen is 10 stable OnePlus 7(Not Pro). Sometimes automatically my ringtones and Notification tones disappears. When it happens no Ringtones and Notification played when i am getting a call or Notification. Tell me what to do? Is it a system bug??
  2. stefg27
    Cupcake Oct 20, 2019
    sammy7838 likes this.
  3. Vipul43
    wchinni and L1532019305094 like this.
  4. stefg27
    stefg27 , via OnePlus 7 Pro , Oct 20, 2019 :
    That's strange!! After restart, I've got back all the ringtones and notification sounds. I'm pretty sure that I've restarted my phone after update.
  5. AbhinavHanda
    Cupcake Oct 28, 2019
    AbhinavHanda , Oct 28, 2019 :
    I have the same problem.. it happens again and again and then the phone needs to be restarted.
    Is there a permanent solution to this problem?
    It gets very annoying.
    JacKok and sammy7838 like this.
  6. sammy7838
    Froyo Oct 29, 2019
    sammy7838 , Oct 29, 2019 :
    Restarted my phone on multiple occasions. Still the issue persists. WhatsApp notifications are only thru vibration even when the phone is on RING. Weird update.
    S1585894644657 likes this.
  7. #7
  8. Eslam AbdelBary
    Cupcake Nov 7, 2019
  9. #9
    I1577458317650 likes this.
  10. mistur
    Cupcake Dec 11, 2019
    mistur , Dec 11, 2019 :
    Dear Support,
    I also have the same issue, trying to get some trace log, which catergory of trace do you need ? Thanks.
    Best regards,
  11. id1204317
    Cupcake Dec 19, 2019
    id1204317 , via OnePlus 7 Pro , Dec 19, 2019 :
    I've got the same problem, it's annoying to feel that I need to check in on the setting to know if I'll hear if someone is calling me or not. Please fix this!
  12. JacKok
  13. I1577458317650
    Cupcake Dec 27, 2019
    I1577458317650 , Dec 27, 2019 :
    Thank you.. Defined custom tone using Zedge app, this solved my issue.
  14. edmund yap
    Donut Dec 29, 2019
  15. L1532019305094
    Cupcake Dec 30, 2019
    L1532019305094 , Dec 30, 2019 :
    I had the same problem but it got rectified after I restarted the phone. Even if you have rebooted after update, please restart once more.
  16. cpugeek75
    Cupcake Jan 5, 2020
    cpugeek75 , via OnePlus 6 , Jan 5, 2020 :
    Solution found. Open the Google Messages Menu and tap Settings.
    General
    Notifications
    Behavior, sounds & more
    Other notifications
    Advanced
    Sound
    From there you will probably see that it is set to Ringtone from internal storage and that below it, it says No ringtone selected. Just choose your favorite ringtone from the list and close it.
    The other solution is to go into every one of your contacts and give them a ringtone. I really don't have the time for that so the above solution worked better for me 😎.
  17. HellsDelight
    Froyo Jan 18, 2020
    HellsDelight , Jan 18, 2020 :
    Issue happened first time for me after weeks of using 10.0.3 with OnePlus 7 Pro.
    Restart fixed it again.
  18. Pal_ur
    Cupcake Feb 19, 2020
    Pal_ur , Feb 19, 2020 :
    Same problem here. I think, it comes up, after I changed to vibration mode and than back. Restarting solves the problem, but I don't think, that should be the ultimate solution :) (Oneplus 7 with Android 10)
    colin1985 likes this.
  19. JacKok
    Cupcake Mar 5, 2020
  20. mardiie
    Cupcake Mar 27, 2020
    mardiie , via OnePlus 7T , Mar 27, 2020 :
    I have the exact same issue on the 7T.
    A restart fixed it.
    edit: It seems like there is an OTA update available. I had to manually refresh my updates. I will report back.
