4
No rply from OP in forum . Let's use Twitter to report battery drain issue using #letusSETTLE
  1. Umang Dua
    Froyo Sep 16, 2016
    Umang Dua , Sep 16, 2016 :
    Guys, there is no rply from OP in forum. Let us use Twitter to report battery drain issue.
    I am constantly writing them on Twitter using #letusSETTLE.
    If we all do the same . It will affect OP and i hope they will provide a proper solution.
  2. amitsamal
    Froyo Sep 16, 2016
    amitsamal , Sep 16, 2016 :
    Can you provide details on which app or component is causing battery drain. Do search the forum as many users have found solution to battery drain issues occuring from multiple sources. It is always advisable to do a clean update to minimize issues
    Mr. BG and Tokolozi like this.
  3. Ceasedd
    Marshmallow Sep 16, 2016
    Ceasedd , Sep 16, 2016 :
    I don't have OP2 battery issues,so no.
  4. eye842
    Lollipop Sep 16, 2016
    eye842 , Sep 16, 2016 :
    Never ever had any battery drain that I could slander One Plus for.
    Check your apps and settings.
  5. vasgou
    Gingerbread Sep 16, 2016
    vasgou , Sep 16, 2016 :
    My battery was good but after the latest update its awesome. I get like 15% more use. Super happy . O I guess I'm kinda settled here
  6. mayursawant
    Ice Cream Sandwich Sep 16, 2016
    mayursawant , Sep 16, 2016 :
    no issue regarding battery drain at all.you are the only one who has having the battery issue. check your apps properly and find out which app is the culprit. most of the time it's the apps coding not been done properly which causes battery drain. check for all apps which you had updated recently.
    jerrymilton, Ceasedd and amitsamal like this.
  7. naveen424
    naveen424 , Sep 16, 2016 :
    I'm getting 7hrs sot update improved batteryb
  8. chris_wds
    Honeycomb Sep 16, 2016
    chris_wds , Sep 16, 2016 :
    Tweet and they will laught at you
    Just try to contact custommer service and tell them your problem
    I think that's it's not the OS that is not optimized but the battery itself that is shit
    But maybe I'm wrong
    IvanMuse likes this.
  9. Yupet
    Yupet , Sep 16, 2016 :
    dude you are obstinately, very annoying but obstinately.
    Go tweet what you want, but go. Thank you
  10. Jaswanth11
    Froyo Sep 16, 2016
    Jaswanth11 , Sep 16, 2016 :
    I also have an issue .the idle drain is huge.drains almost 18% in 8 hrs.cleared the cache but it is of use the idle drain still persists
    akaashachuu and Umang Dua like this.
  11. Gorkhey
    Gorkhey , Sep 16, 2016 :
    How do you manage to get 7hrs SOT, I barely get 3hrs with minimum use, do you mind sharing some tips.
  12. Yupet
    CM13 for me works. also get about 7 hours.
  13. dipta.ds
    dipta.ds , Sep 16, 2016 :
    I don't have any issues with the battery performance. There is obviously something wrong if you're getting really bad battery life. I am a moderate user (no games, browsing, fb(liite), whatsapp, twitter, tumblr, youtube, music) and i easily get around 4.5 hours SOT. Your issue could be due to any app keeping your phone awake, wakelocks. Try using greenify and do some search in the forum for solutions instead flooding twitter, you will get better results. Cheers
  14. Tscope
    Froyo Sep 16, 2016
    Tscope , Sep 16, 2016 :
    Disable Twitter And you will get 12 hours SOT over 2 days,,,
  15. Umang Dua
    Froyo Sep 16, 2016
    It's Android system and Android OS that is primarily draining my battery and SOT is rnd 3.5 hrs with normal usage .
  16. VENKAT11214
    Froyo Sep 22, 2016
    Umang Dua likes this.
  17. Starbomba
    Eclair Sep 22, 2016
    Starbomba , Sep 22, 2016 :
    I have 7-8 hrs of screen on time, and 2 hours charge time from 15% to full. On stock OOS 3.1.0 with custom kernel. No other social network other than FB installed.
  18. adarsh majhi
    Eclair Sep 22, 2016
    adarsh majhi , Sep 22, 2016 :
    7 hrs? Dude how do you manage that.
    anz563 and Umang Dua like this.
  19. naveen424
    Gingerbread Sep 22, 2016
    naveen424 , Sep 22, 2016 :
    I don't know mine takes 30min more to charger and also holds that CHarge fr long and also noticed no heating while charging and multitasking laggs
  20. malidan
    Nougat Sep 22, 2016
    meatandy likes this.
