4
No rply from OP in forum . Let's use Twitter to report battery drain issue using #letusSETTLE
  1. Umang Dua
    Froyo Sep 22, 2016
    Umang Dua , Sep 22, 2016 :
    I don't even remember if i ever got 7 hours of SOT.
  2. Umang Dua
    Froyo Sep 22, 2016
    U r kidding right.
    It's impossible in today's world.
    That too with OP2. I cannot even imagine that in my dreams
  3. malidan
    Marshmallow Sep 22, 2016
    malidan , Sep 22, 2016 :
    Agreed, but do you see how easy it was for me to say it though;)
    elhasi and IvanMuse like this.
  4. Starbomba
    Eclair Sep 22, 2016
    Starbomba , Sep 22, 2016 :
    Hell, i remember my Xperia A getting like 12-14 hrs of SOT and 2 days battery. It's not impossible, if you get your hands a bit dirty and really #neversettle with the whole OEM software. Make the phone yours and the hardware will really amaze you.
    IvanMuse likes this.
  5. TlathamXmahtalT
    KitKat Sep 22, 2016
    TlathamXmahtalT , Sep 22, 2016 :
    This!
  6. rylegood
    Gingerbread Sep 22, 2016
    rylegood , Sep 22, 2016 :
    I was getting 2 hrs SOT. Now I'm at 8 hrs SOT with OxygenOS. I did a factory reset and totally reset the whole phone. It made a world of difference.
  7. Chiragjain.jain25
    Honeycomb Sep 23, 2016
    Chiragjain.jain25 , Sep 23, 2016 :
    Since I have upated my phone sonetimes I not able to listen the sound of calls or msg and touch sounds .
    Then I have restart mobile and after sometimes it happens again...
    Plzz help me...
  8. Umang Dua
    Froyo Sep 23, 2016
    Umang Dua , Sep 23, 2016 :
    ;D
  9. Umang Dua
    Froyo Sep 23, 2016
    I am afraid to play with my Phn .
  10. Umang Dua
    Froyo Sep 23, 2016
    Even tried that .
    Does not help .
    Nyways thanks
  11. Umang Dua
    Froyo Sep 23, 2016
    Try cleaning cache.
  12. Tscope
    Froyo Sep 23, 2016
    Tscope , Sep 23, 2016 :
    Just been 6 days on meditation festival without phone, I left it on my desk with the battery on approx 80% no Grenify ETC. there was still 28% juice left when I came home this morning, thereafter a quick call to my Mom, and then a good charge approx 38 min. later 100 Percent juice
  13. Chiragjain.jain25
  14. Starbomba
    Eclair Sep 23, 2016
    Starbomba , Sep 23, 2016 :
    Be afraid if it is a Samsung. Knox can give you hell. OP2? I had it updated to the latest version (3.0.2 to 3.1.0), unlocked bootloader, installed custom recovery, rooted and flashed with a custom kernel in like 30 minutes. In fact, i used This guide to do so.
  15. elhasi
    Gingerbread Sep 26, 2016
    elhasi , Sep 26, 2016 :
    How will following these steps miraculously improve my battery life? It is still the same ROM? Or how does this all improve your battery life?
  16. Lancelot_69
    Lollipop Sep 26, 2016
    Lancelot_69 , Sep 26, 2016 :
    Go to settings -apps - google play services -delete data and cache then go to settings backup and reset and turn off then reboot . This should solve your problem .
  17. viraaj11
    Community Veteran Sep 26, 2016
    viraaj11 , Sep 26, 2016 :
    Screenshot taken on 19 September 2016. Stock Oxygen OS. Non rooted. Worth noting I don't have Facebook installed and GPS was turned off. Most use was Chrome, BaconReader(reddit client) and YouTube. Brightness was around 50%. Also I had a GPS issue with the PlayStore causing a wakelock yet it managed to give this SoT. But then again it's worth noting the constant use of the phone and didn't leave it idle for long periods. On an average day it lasts for about 16 hours with 5h30m of SoT with GPS use of around 15-20 minutes with WiFi or 3G always on.
  18. BoBi1234
    Cupcake Sep 26, 2016
    BoBi1234 , Sep 26, 2016 :
    I have battery drain problem on my OP2, after i switch to OP3 I have noticed same issue, only difrence was antutu benchmark on second place. After i remove antutu android system wasnt on first place in battery use, when i remove it on OP2, result was the same, battery drain fixed.
    #38
  19. tyor
    #39
