No signal for sim slot 2 via OnePlus 8T
  1. AkashDio
    Cupcake Jan 20, 2021
    AkashDio , via OnePlus 8T , Jan 20, 2021 :
    Suddenly the signal on the second slot sim is disabled. Not able to connect to it again. Showing no signal. As I'm a dual sim user need to get it resolved As early as possible. Please let me know the solution.
  2. psygarden
    Ice Cream Sandwich Jan 20, 2021
    psygarden , via OnePlus 8T Aquamarine Green , Jan 20, 2021 :
    You can try these solutions :
    1. Turn Airplane Mode On and then turn it Off.
    2. Restart the Device.
    3. Take out the Sim Tray and re insert it.
    4. Change Sim slots and check.
    5. Make sure it's not a Network issue.
  3. G_plusone
    Nougat Jan 20, 2021
  4. #4
  5. #6
  6. #7
  7. rizwanqureshi786
    Gingerbread Jan 23, 2021
    rizwanqureshi786 , Jan 23, 2021 :
    Check that sim in other handset. If it works in other handset then It seems a hardware issue then you need to visit service center
  8. Triveni786 , via OnePlus Community App , Jan 24, 2021 :
  9. StefanStark , via OnePlus 8T Aquamarine Green , Jan 24, 2021 :
    Are you serious?
    Copy paste the #1 post in this topic?
    Seems super low effort?
