No Sound for Text or Notification
  1. JNym
    Cupcake Jun 22, 2021
    JNym , Jun 22, 2021 :
    A couple of days ago the texts and notifications went silent and no vibration. I have to open the SMS app to see texts. They arrive but I have no way to know they're there.
    Checked app settings and system settings. All turned on and sounds selected.
    Calls still ring. The Signal SMS app still makes the sound.
    Using OxygenOS 10.3.11, Android 10 on my Oneplus 6.
    Of note. Google Play Store says Oneplus Messages won't update. It says the app in the Store is for Android 11. OK. But it's gave that warning for awhile and my messages still worked until last couple days.
  2. Tobikage
    Nougat Jun 22, 2021
    Best Answer
    Tobikage , Jun 22, 2021 :
    The app should still wprk regardless of whether it gets the latest update u less there's anybugs in the version installed on your phone.
    Check all sound settings again.
    Check all notifications settings if you've mistakenly toggled anything off.
    rHITkM. and cdnfarmer like this.
  3. JNym
    Tobikage,
    Thank you. It was deep in the app list. Notifications had been turned off. I don't even know how. But all is well thanks.
    Tobikage likes this.
  4. YSRReddy
    Honeycomb Jun 22, 2021
  5. Praveench
    Froyo Jun 24, 2021
    Praveench , via OnePlus 6 , Jun 24, 2021 :
    Excellent
  6. Ankita_S.
    OnePlus Bug Hunter Staff Member Jun 25, 2021
    Ankita_S. , Jun 25, 2021 :
    For analyzing this better we would need more details & to get this sorted out at the earliest. We've dropped you a personal message and would request you to respond to the same.
    Regards,
    Ankita
