No voice input through headphones mic connected with aux converter in OP 7t after Android 11 update. via OnePlus 7T
  1. Z1574833893199
    Cupcake Oct 18, 2021
    Z1574833893199 , via OnePlus 7T , Oct 18, 2021 :
    Since 2 years I was using my headphones through aux to type C converter. But recently after the android 11 update in OnePlus 7t , the voice is not going to the other caller though I can hear his voice , but my voice is not going . I checked it at OnePlus service center and they told the same it's a software update issue and they told that it I want to again use it then they can downgrade the update and I can use again. But due to that many things which is in android 11 will also be missing.
    So please OnePlus team please fix it ASAP in OnePlus 7t device.
  2. J4t1np4r3kh
    OnePlus Accessory Tester Oct 18, 2021
    J4t1np4r3kh , Oct 18, 2021 :
    I guess if the service centre have said that it's an update issue, then rolling back is your only solution for now.
    However, you should generate a bug report and attach your logs so that in the next update this issue can be resolved
  3. hbk1402
    KitKat Oct 22, 2021
