VidhyaSJ , via OnePlus 8T , Oct 28, 2021 : I am facing problem with no whatsapp notification sound and vibration in vibrate mode as well as in ringing mode, For your information I have reinstalled what's over 20+ times, thinking of issues with whatsapp but no use its still the same, Also wiped my phone twice and still the result is same, Someone from OnePlus solve this issue...
psygarden , via OnePlus 8T Aquamarine Green , Oct 28, 2021 : Having no issue here. Did you check the Notification Settings in both WhatsApp and Phone Settings?
Dresa91 , Oct 28, 2021 : Hey, the latest Beta of WhatsApp fixes the issue: https://wabetainfo.com/whatsapp-beta-for-android-2-21-22-8-whats-new/ „WhatsApp hatte in der Beta zuletzt einen Bug, der sich durch mehrere Versionen zog: So gab es bei eingehenden Nachrichten keinen Notification-Ton mehr. Mich selbst störte das nicht so, da mein Smartphone grundsätzlich stumm geschaltet läuft. Wer sich darauf verließ, ärgerte sich aber sicherlich. Mit der Android-Beta 2.21.22.8 gehört der Fehler nun wieder der Vergangenheit an.“ -> „ WhatsApp recently had a bug in the beta that was present in several versions: There was no notification tone for incoming messages. This did not bother me that much, since my smartphone is always on mute. However, those who relied on it were certainly annoyed. With the Android beta 2.21.22.8, the bug is now a thing of the past again. „ Source: https://stadt-bremerhaven.de/whatsapp-beta-2-21-22-8-fuer-android-behebt-den-notification-bug/(German blog)
psygarden , via OnePlus 8T Aquamarine Green , Oct 28, 2021 : If you're on a beta then check the above post by @Dresa91 and update to latest beta version. If the update is not available on Play Store then download via apkmirror
VidhyaSJ , via OnePlus 8T , Oct 28, 2021 : I'm already running on the same beta version since 3 days, still the same...
Dresa91 , Oct 28, 2021 : This beta was published Tuesday.. https://www.apkmirror.com/apk/whatsapp-inc/whatsapp/whatsapp-2-21-22-8-release/
VidhyaSJ , via OnePlus 8T , Oct 28, 2021 : Yes as I have mentioned, I've reinstalled whatsapp over 20 times within a day and I've even wiped my phone too
psygarden , via OnePlus 8T Aquamarine Green , Oct 28, 2021 : If you're using a beta then you'd be familiar with the buggy updates. This is not a OnePlus issue and the better place for feedback would be WhatsApp Play Store account, send a feedback to WhatsApp devs with logs attached. Or just move to stable version as I can confirm the latest stable version has no such issue.
Dresa91 , Oct 28, 2021 : Well,… you also mentioned that you were using this WhatsApp beta version since Monday,.. although this has only been published Tuesday. Contact the support of WhatsApp via https://www.whatsapp.com/contact/
BetaBot , via OnePlus 8T Aquamarine Green , Oct 28, 2021 : Beta version will always have some issues. Use stable only
