5
Non-CM-Based ROM you should check out: BrokenOS
Thread Status:
Not open for further replies.
  1. vivek289
    Ice Cream Sandwich May 19, 2015
    Milad likes this.
  2. momoclax
    Donut May 19, 2015
  3. redleema
    KitKat May 19, 2015
    vivek289 likes this.
  4. vivek289
    vivek289 , May 19, 2015 :
    battery drain is really good(at least for me), As you can see many tweaks that you can apply form the ROM itself (see the screen shots)
    momoclax likes this.
  5. camohan
    Assistant Head Moderator Assistant Head Moderator May 19, 2015
    camohan , May 19, 2015 :
    Done with ur investigation hahaha damn funny little buddy
    rbagdai likes this.
  6. redleema
    KitKat May 19, 2015
  7. vivek289
  8. Jawad973
    Jelly Bean May 19, 2015
    Jawad973 , May 19, 2015 :
    Can anyone tell me how to enable V4A? Never used it before. It doesn't seem to work whichever player I try to use. I did try to install and uninstall the drivers but no luck.
  9. vivek289
    You need to install the driver first and config it
  10. Jawad973
    Already tried. Still nothing.
  11. royz0r
    royz0r , May 19, 2015 :
    But does it include the latest sypnapics firmware? Either i will flash it right away
  12. Wishmaster
  13. GiveMeThePhoneAlready
    Eclair May 19, 2015
  14. return.of.octobot
    return.of.octobot , May 19, 2015 :
    It's a bug the only permanent way to doable it thus far it via GravityBox.
    OP Thanks for jackin my idea BTW :p
    Jawad973 likes this.
  15. Jawad973
    Okay. V4A doesn't work for me. :/
  16. vcespon
    Gingerbread May 19, 2015
    vcespon , May 19, 2015 :
    Pffff.. This, the batman logo, the logo with green goo dropping... this was made by a 13 year-old. Are you aiming at adult people using your ROM for anything serious? Because just seeing that stuff makes me not wanting to trust my personal info on your stuff... can be full of password stealing code or botnet enabling troyan horses.
  17. Takendown
  18. return.of.octobot
    I noticed they had V4A installed to system/ app, as far as I always knew it's supposed to be installed to system/ priv-app, so I removed their preinstalled version, reflashed myself and it worked fine.
    Also, you're SELinux mode should be set to permissive, you can also try enabeling Awesome Player in developer options.
    #38
  19. return.of.octobot
    *judges book by cover, misses out on stellar ROM*
    #39
    DaxNagtegaal, alohanico and Takendown like this.
  20. Jawad973
    Can you help me out with it? I never used Viper so don't know much about it.
    #40
