9
Nord 2 lag in videos and scroll
  1. Shailender Sharma
    Nougat Oct 16, 2021
    Shailender Sharma , Oct 16, 2021 :
    Wipe Cache Partition
    Cache Partition stores temporary data for speeding up your android system. But some times you may need to clear this partition without erasing all other data.
    It only clears the Cache, your data is safe, just follow the steps :-
    1. Power off the phone.
    2. Wait until the device is completely off.
    3. Then press and hold the Power and Volume Down (-) buttons at the same time.
    4. Continue holding these two buttons during the initial OnePlus splash screen.
    5. When the OnePlus logo goes away, you can let go of these two buttons.
    6. And then wait until the phone boots into Recovery Mode.
    7. If you have a password set, you will have to enter the pin to decrypt(basically unlock access to storage) here.
    8. Tap on the language of your choice.
    9. Tap on the Wipe Data and Cache option.
    10. Tap on the Wipe Cache option.
    11. Tap the Yes option when asked to confirm.
    12. Wait for the phone to clear the cache partition.
    13. Then tap on the Reboot option to restart the phone.
    #81
  2. shantharam cr
    Cupcake Oct 16, 2021
    shantharam cr , Oct 16, 2021 :
    Nord 2 doesn't have this option so can u please recommend any other possible solution .Even basic features like calls r laggy
    #82
  3. Shailender Sharma
    Nougat Oct 16, 2021
    Try to clear the Phone app cache in the Settings and restart your device once.
    Also, try to Reset WiFi, Mobile & Bluetooth -
    Settings - System - Reset Options - Reset WiFi, Mobile & Bluetooth.
    It might help.
    #83
  4. shantharam cr
    tried all of the mentioned methods nothing seems to work . I must visit the service center now no other option ig
    #84
  5. atuloroskar
    Donut Oct 17, 2021
    atuloroskar , via OnePlus Nord 2 , Oct 17, 2021 :
    I have wiped cache partition as per the steps mentioned.
    The phone worked well for few minutes but same issue afterwords. The phone has started lagging as it is earlier. This is a huge disappointment.
    Feeling help less now. Cant this be solved ?
    #85
  6. Shailender Sharma
    Nougat Oct 17, 2021
    Shailender Sharma , Oct 17, 2021 :
    Have you updated to the latest OxygenOS A.11 for the OnePlus Nord 2 5G?
    If yes, then Back-up all your phone data to laptop/PC/external storage (physical/cloud etc.) and factory reset your phone. Double check your backed up data before factory resetting the phone.
    #86
  7. atuloroskar
    Donut Oct 18, 2021
    atuloroskar , via OnePlus Nord 2 , Oct 18, 2021 :
    Yes I have already updated the OxygenOs.
    Could you please share the steps to perform factory reset?
    #87
  8. Shailender Sharma
    Nougat Oct 18, 2021
    Shailender Sharma , Oct 18, 2021 :
    Double check the back up data before performing the factory reset. Search Reset Options in the Settings - System
    #88
  9. N1628078413205
    Cupcake Oct 20, 2021
    N1628078413205 , Oct 20, 2021 :
    Hi, I recently bought one plus Nord 2 8GB variant and after 1 month I am facing lag issues while playing games, using social media applications, and other apps. Please help me with this.
    #89
  10. Puskarmehta
    Cupcake Oct 30, 2021
    Puskarmehta , via OnePlus Nord 2 , Oct 30, 2021 :
    I had the same problem and even after restarting,
    the phone hangs and starts freezing in 2-3 minutes....
    Here you can do to resolve the issue as i do
    1) unlock developer mode
    2) in developer mode go to running services
    3) click every app and press STOP
    until your phone is your phone again
    if needed open show catched process and do 3rd step .
    Lets hope one plus fix this issue in the next update and update come soon ...Really frustating to use this device.
    #90
  11. X1634042287360
    Cupcake Nov 1, 2021
    #91
  12. Puskarmehta
    Cupcake Nov 11, 2021
    #92
  13. Peter@95
    Peter@95 , via OnePlus Nord 2 , Nov 11, 2021 :
    Hi guys ,
    If you are facing any lag issue on your nord 2 , please follow the below steps.
    Go to settings >> click on App management>> (you will see the bank apps without name and logo) >>un-install that particular unwanted apps >> restart your mobile.
    For sure it will get fixed.
    #93
  14. C1625730724981
    Cupcake Nov 13, 2021
    C1625730724981 , Nov 13, 2021 :
    Hi, got the Nord 2 a fortnight ago and the lagging is outrageously irritating, can't type without lag, scrolling is lagging, I restart the phone and it goes back to normal for some time then back to lagging, please help
    #94
