7
nord battery optimisation via OnePlus Nord
  1. X1596561882927
    Cupcake Aug 6, 2020
    X1596561882927 , via OnePlus Nord , Aug 6, 2020 :
    Hi, I have recently purchased nord. Battery is draining faster with normal usage. No games played, only standard use of the phone.
    Will battery optimisation update be released?
    Is there anyway battery drainage can be optimised?
    please suggest.
  2. C1596601101050
    Cupcake Aug 6, 2020
    nansastra likes this.
  3. E1596616529880
    Cupcake Aug 7, 2020
    nansastra and Krunal_221 like this.
  4. igarvitmehta
    Cupcake Aug 7, 2020
  5. Rohit_india130
    Cupcake Aug 7, 2020
    Rohit_india130 , via OnePlus Nord , Aug 7, 2020 :
    Even i had the same problem, Follow the steps in this photo, the problem will get sorted out
  6. Iwen X.
    OnePlus User Ambassador Staff Member Aug 7, 2020
    Iwen X. , Aug 7, 2020 :
    Hi Bro, could you help catch log so that we could figure out what happened. Thank you.
  7. E1596616529880
    Cupcake Aug 7, 2020
    E1596616529880 , via OnePlus Nord , Aug 7, 2020 :
    how to catch the log? still I am still having battery drainage issue
  8. E1596616529880
    Cupcake Aug 7, 2020
  9. Rohit_india130
    Cupcake Aug 7, 2020
    Pls proceed ahead in the process for replacement, brother. Thanks
  10. F1586971912041
    Cupcake Aug 8, 2020
    F1586971912041 , via OnePlus Nord , Aug 8, 2020 :
    hello one plus I hope you will make someone time and check my our (Nord community? quaries
    I have bought an OnePlus Nord recently . personally i am a big fan of OnePlus devices
    so there are some issues i have found while using it
    1.battery drain
    2.The images captured from front facing camera were too much blurry and the low light images are also were too dull and lot of noice in the image .
    3.lastly, the after clicking the image the hand should be still for 1-2 seconds or more or else the final product of images are very blue both with front and back cameras
    SujayBK likes this.
  11. Tusssu
    Eclair Aug 8, 2020
    Tusssu , via OnePlus Nord , Aug 8, 2020 :
    Yeah i am facing the same issue , battery is draining like its 3000mqh not 4115mah, my OP3 (4yrs older) is doing more good in battery department.
  12. V1575973371079
    Cupcake Aug 13, 2020
    V1575973371079 , Aug 13, 2020 :
    Hi ,
    Still you are facing this issue after update the version . If yes could you please share me the
    Scenario details and logs .
    Please share the % of battery before using and after usage of device .
    1.Phone---*#800#---Enter
    2.Basic log--setting icon--Log save location--/sdcard/oem_log&get bugreport when stop logging-Enter
    3.Back--open the log switch
    4.reproduce the issue
    5.Phone---*#800#---Enter--close the log
    6.File Manager---Storage---Internal storage---find the oem_log file folder---Compress ,shared it to us via Google drive or any cloud drive.
