15
Nord Display tint Issue.
Are you having a display issue (tint/black line notch/...)
  1. Yes, I'm having issues
    40 vote(s)
    78.4%
  2. No, I'm not having any issues.
    11 vote(s)
    21.6%
  1. karkyaal
    Froyo Aug 16, 2020
    karkyaal , Aug 16, 2020 :
    i have sent the device for refund now. 😑
    #61
  2. haripunukollu
    Cupcake Aug 17, 2020
  3. Sumit_Sukhija
    Cupcake Aug 18, 2020
    #63
  4. Christo2303
    Honeycomb Aug 20, 2020
    #64
  5. shadynit
    Gingerbread Aug 21, 2020
    shadynit , Aug 21, 2020 :
    I am having the same issue. purple, green tint visible on white background.
    See the below image.
    #65
  6. shadynit
    #66
    i_am_madmaxx likes this.
  7. P1597421749473
    Cupcake Aug 23, 2020
    P1597421749473 , Aug 23, 2020 :
    This is not a common issue in the AMOLED displays? I believe this is not 1+ specific...
    I have similar situation - dark theme with full white background (green tint). But not (so much) perceptible when with text.
    #67
  8. Afnan_542
    Cupcake Aug 25, 2020
    Afnan_542 , Aug 25, 2020 :
    I am facing dark pink tint issue at bottom of the display under 30% brightness its cleary visible in darkmode enabled background... Please fix
    #68
  9. Sathiya Prabhakaran
    Cupcake Aug 26, 2020
    Sathiya Prabhakaran , Aug 26, 2020 :
    Yes, this issue is seen while in white screen also and not only with grey screen. the green and pink tint is clearly visible in off axis IMG_0509.jpg IMG_0515.jpg
    #69
    shadynit likes this.
  10. R1598493304876
    Cupcake Aug 27, 2020
    R1598493304876 , Aug 27, 2020 :
    Amoled displays in samsung m series phones didn't have these tint issues.The oneplus team saying that tints are common in oled displays. Oneplus is getting worse. These tints are because of manufacturing defects. I'm not sure that they will fix through software update. If you have any issues replace or return it. Oneplus 8 pro and nord are having tint issues. If you're planning to buy these devices please note that it having unbearable tints that affect your display experience.
    #70
  11. R1598493304876
    #71
  12. Nilabhro_
    #72
  13. P1597421749473
    P1597421749473 , Aug 27, 2020 :
    I was googling and Samsung is suffering the same... or even worse.
    https://www.gsmarena.com/some_samsu...ting_a_green_screen_tint_issue-news-42675.php
    #73
  14. Sahil_Verma001
    #74
  15. torque.hunter
    Cupcake Aug 28, 2020
    #75
  16. Febin Malik
    Febin Malik , Aug 28, 2020 :
    I also have a tinting issue around 30% battery level, and charging speed also very low
    #76
  17. G1598087941437
    G1598087941437 , Aug 28, 2020 :
    I too am having the same issue of this tint. When the phone is in low brightness and in dark mode I am having pink tints spreading from the right edge of the phone towards the centre. Very disappointed with it. And I having a significant sudden battery drain which I hope will be sorted by today's update which takes that too into consideration. If the display issue is a software issue please sort it out in an immediate update
    #77
  18. L1597303442371
    L1597303442371 , via OnePlus Nord , Aug 28, 2020 :
    Have you gone to the service center?
    If yes,how did they help you?
    #78
  19. i_am_madmaxx
    i_am_madmaxx , via OnePlus Nord , Aug 28, 2020 :
    I applied for an RMA online....it got cancelled by itself! I live in Mumbai and the service centre is closed. Can't do shit, using the phone at 60hz for less tint. No other option.
    #79
  20. L1597303442371
    I went to the service center today,they said that it's a software defect which will get resolved with the new update...But I really doubt that an update will sort this out, I believe it's a hardware defect.
    #80
