3
Nord issues and bugs via OnePlus Nord
  1. Ashwin Mathews
    Donut Sep 16, 2020
    Ashwin Mathews , via OnePlus Nord , Sep 16, 2020 :
    OnePlus Nord, am awesome phone but there are some issues and bugs need to be solved with emergence.
    1. Bluetooth connectivity issue - it ain't solved with the 10.5.7 update. Gets disconnected randomly while playing games and call comes.
    2. Battery drain issue - drains battery quickly
    3. Screen tint issue still exist as increasing dark background doesn't solves the tint issue.
    4. Network drop issues in mobile data - when using mobile data it shows you're offline if we do have a strong connection too. While playing games the connection gets lost in mobile data, while in WiFi its perfect and no issues at all.
    5. Processing system gets stopped working when Bluetooth disconnect issue encounters.
    So hope OnePlus team will solve this issues ASAP.
    Thanks.
  2. DinethIrusha
    Gingerbread Sep 16, 2020
    DinethIrusha , Sep 16, 2020 :
    1. Use the feedback tool and use the bug report.
    2. Battery's are suppose to drain if you're using it hard,
    3. Use the feedback tool and use the bug report.
    4. I guess that's gotta do with your mobile operator contact the mobile operator regarding this
    5. Use the feedback tool and use the bug report
    Caomhin likes this.
