Not able to connect my oneplus 7t to android auto
  1. G1580006341106
    Cupcake Feb 21, 2020
    G1580006341106 , Feb 21, 2020 :
    i am trying to connect my oneplus 7t to my swift car but not able to connect properly. At starting it tries to connect after that it disconnects and shows no phone connected. I even tried with orginal cable then also not connected
  2. NeonX89
    Gingerbread Feb 21, 2020
    NeonX89 , via OnePlus Community App , Feb 21, 2020 :
    Is Android auto fully updated?
    That could be one issue.
    Or could be an improper setting if you Uninstall
    then re-install and set it up again.
    "Some cars can android auto over Bluetooth/wifi"
    Some cars can have extra software you have to go through to enable so i have no idea but hopefully this might help a little bit.
    Worse case draws to much power it disconnects from the port?
    Or port Damaged...
  3. G1580006341106
    Cupcake Feb 22, 2020
    G1580006341106 , Feb 22, 2020 :
    ya its fully update and no issue of cale also
    same cable working well with samsung phone
    installed twice anroid auto but not showing in apps
    but as i connect my phone to car via usb it starts andriod auto and then disconnects
    but working well with bluetooth
    but it doesnot connects map and other things
  4. NeonX89
    Gingerbread Feb 22, 2020
    NeonX89 , via OnePlus Community App , Feb 22, 2020 :
    The app is built onto the phones OS so it won't show up in the app list.
    But if you fully set it up and it's not functioning? You might want to wait for the next Android auto update 🤔 and try again. Sounds like something needs to be re-connected & set up.
    G1580006341106 likes this.
  5. Bsingh7TProM
    Donut Mar 1, 2020
    Bsingh7TProM , Mar 1, 2020 :
    I have same issue on my OnePlus 7T Pro. Apparently, it is an issue with OnePlus devices. My other phone, a Nokia 8.1 on Android10 works well with the same car and is rock solid. On official AA forums, it is also mentioned that it is OnePlus issue but there has been no fix so far, for the past 3 - 5 months. OnePlus support keeps asking for logs everytime you reach out to them for resolution. But even after providing logs in December, 2019, there has been no resolution. It is pathetic, really.
    Th3Gold3nRainbow likes this.
  6. G1580006341106
    Cupcake Mar 5, 2020
  7. Bsingh7TProM
    Donut Mar 5, 2020
  8. Montucky
    Ice Cream Sandwich Mar 5, 2020
    Montucky , Mar 5, 2020 :
    I have run into this with a few smart cars. Make sure bluetooth/location is on, sometimes they use bluetooth to setup the connection securely and it needs LOCATION on as well. Some even need NFC on for some weird reason.
  9. Z1566136813596
    Cupcake Mar 28, 2020 at 1:51 PM
    Z1566136813596 , Mar 28, 2020 at 1:51 PM :
    what about getting a tutorial on YouTube to show this issue?
    I have a Peugeot 2008 (2017) and my issue is that navigation is not showing up in car display only on my phone (7t).
