Not Able to LOCK OEM.
  1. raman0424 Gingerbread Apr 17, 2019
    raman0424, Apr 17, 2019 :
    After performing the fastboot command to lock the oem its showing done on cmd and even on my phone it's showing the warning screen where we have to select Yes and No to lock the bootloader.
    I select the Yes option were it say lock the bootloader and restart the phone.
    My phone restart but when i go in developer option it's showing me OEM is Unlocked and the option is grey.
    Everytime i restart my phone its showing me the warning screen of OEM is unlocked.
    I'm on stock rom and stock recovery
    Need Help.
    Thanks in advance
  2. YRJ KitKat Apr 17, 2019
    BobbyV8_ and raman0424 like this.
  3. raman0424 Gingerbread Apr 17, 2019
  4. YRJ KitKat Apr 17, 2019
    YRJ, Apr 17, 2019 :
    I have tagged someone who might be able to help, please wait. :)
    athaarv and raman0424 like this.
  5. raman0424 Gingerbread Apr 17, 2019
    Thank you buddy
    YRJ likes this.
  6. athaarv Jelly Bean Apr 17, 2019
    athaarv, Apr 17, 2019 :
    Never run the ADB command to relock your bootloader on a OnePlus device. So many things could go wrong. Best thing to do is run the MSM Download tool and it'll flash it back to full stock for you
    raman0424 likes this.
  7. raman0424 Gingerbread Apr 17, 2019
    can you provide the link of MSM tool
  8. athaarv Jelly Bean Apr 17, 2019
  9. raman0424 Gingerbread Apr 17, 2019
  10. athaarv Jelly Bean Apr 17, 2019
    Follow the guide step by step and remember that you're doing this at your own risk. Don't forget to back up your device first
  11. raman0424 Gingerbread Apr 17, 2019
    Don't worry[e]1f60a[/e]
  12. BobbyV8_ The Showcase Reviewer Apr 18, 2019
    BobbyV8_, Apr 18, 2019 :
    Thanks for the tag.
    Hitting the MSM tool already? Looks like that's a straight jump. Let me know if you still need help with this.
    Can you say what's the command you're running to lock bootloader?
    raman0424 and YRJ like this.
  13. venioni Froyo Apr 18, 2019
    venioni, Apr 18, 2019 :
    "fastboot oem lock" this is the right command to relock your bootloader.
  14. raman0424 Gingerbread Apr 18, 2019
    raman0424, Apr 18, 2019 :
    yes
  15. raman0424 Gingerbread Apr 18, 2019
    "fastboot oem lock"
    This command.
  16. BobbyV8_ The Showcase Reviewer Apr 18, 2019
    You've hit the right spot! No idea as to why it doesn't work.
    Try this once
    Factory reset device
    Flash stock recovery
    Reboot system
    Boot to bootloader
    Lock boot loader - "fastboot oem lock"
    Reboot with "fastboot reboot"
    Check if bootloader is locked or not
  17. anupritaisno1 KitKat Apr 18, 2019
    anupritaisno1, Apr 18, 2019 :
    In TWRP go to the mount section and make sure the "mount system partition read-only" option is ticked
    Flash oxygenos and reboot
    Wait for it to fully boot
    Now check if your recovery was replaced by oxygenos recovery
    After that lock the bootloader
    You can only lock the bootloader if both the boot and recovery partition contain a signed image which is signed with the same key
  18. raman0424 Gingerbread Apr 18, 2019
    buddy I'm on stock rom and stock recovery
