Not able to merge calls
  1. Shiven khurana
    Cupcake Sep 12, 2017
    raval_manish likes this.
  2. Shiven khurana
  3. nitd24
    Gingerbread Sep 12, 2017
    nitd24 , Sep 12, 2017 :
    You might have to call your carrier and check if you have conference calls activated. If not, ask them to activate.
    I've faced a similar issue a couple years back.
  4. vinay veera
    Eclair Sep 12, 2017
    vinay veera , Sep 12, 2017 :
    if you are trying to merge calls from two different Sims/network then you cannot. can only merge calls from the same network.
  5. innocentdevil.sid007
    Honeycomb Sep 12, 2017
  6. raval_manish
    Cupcake Nov 19, 2017
    raval_manish , Nov 19, 2017 :
    It's for merging of calls from same number in call log. not related to conference or merge live call.
    pl suggest if it's possible to merge.
  7. F1563519648940
    Cupcake Dec 6, 2019
    F1563519648940 , Dec 6, 2019 :
    Its same sim but unable merge calss,
    On One plus only facing this issue..
    Earlier i i w using honor . No issues at all.
  8. silver735
    Cupcake Dec 6, 2019
    silver735 , Dec 6, 2019 :
    Hi, contact your operators, then try to download an app to chat call if the problem persists!
