Not able to open community on my WiFi via OnePlus 8T Aquamarine Green
  1. Shivnshkhatana , via OnePlus 8T Aquamarine Green , Mar 24, 2021 :
    Whenever I open OnePlus community on my WiFi it just keeps reloading , I am using airtel and it has a poor connectivity in the area am living therefore I have to use wifi for calling and internet every freaking time . I even can't watch YouTube on my mobile data it's that pathetic.
    Don't know what to do help people!
    Syrix likes this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 25, 2021
    Bobbie63, Shivnshkhatana and McJader like this.
  3. Shivnshkhatana
    Froyo Mar 29, 2021
    Caoimhín likes this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 29, 2021
    Bobbie63 and Shivnshkhatana like this.
  5. Shivnshkhatana
    Froyo Mar 29, 2021
    Shivnshkhatana , via OnePlus 8T , Mar 29, 2021 :
    Yes sir all other apps are working smoothly it's only with community. I can operate it via chrome easily but just wanted to know whether it is due to some settings or just a glitch.
  6. BeingIncog
    Nougat Mar 29, 2021
    BeingIncog , Mar 29, 2021 :
    check app's info page there you can check settings like this : Screenshot_20210330-002823__01.jpg
  7. Shivnshkhatana
    Froyo Mar 29, 2021
  8. BeingIncog
    Nougat Mar 29, 2021
    okay, can you check the router's settings? also reset the networks...
    you can access forums : forums.oneplus.com
    Bobbie63 likes this.
  9. Caomhin
    Caomhin , via OnePlus 6T , Mar 29, 2021 :
    It may be a permissions issue.
    Reset the App permissions, it may be that an app or apps or something connected is causing the issue.
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    ⚠️This will not delete your apps data but you will have to provide permissions for All your Apps again.⚠️
  10. Shivnshkhatana
    Froyo Mar 29, 2021
    Thanks buddy , I guess I'll just use it on mobile data for now and will post in general support .👍🏻
    Caoimhín and .Deleted_Member. like this.
  11. Bobbie63
    Marshmallow Mar 29, 2021
    Bobbie63 , Mar 29, 2021 :
    Or use the community section through the webbrowser. :rolleyes:
    Caoimhín and Shivnshkhatana like this.
  12. Shivnshkhatana
    Froyo Mar 29, 2021
  13. Caomhin
    Just one other suggestion, you could try Uninstall Updates if available for the community app, just in case a newer version is new functioning correctly.
    To do so, open Community App info, click on the 3 dot menu top right and select Uninstall Updates.
    You will have to login again. But worth a try. Best of luck. 👍
  14. Shivnshkhatana
    Froyo Mar 29, 2021
    Already tried twice 😕
