Not Compatable with Amazon Prime Music!?!?
How do you Jam with your OPO?
  1. Amazon Prime (if you could)
    7 vote(s)
    30.4%
  2. Spotify
    7 vote(s)
    30.4%
  3. Google Play Music
    7 vote(s)
    30.4%
  4. Pandora
    2 vote(s)
    8.7%
  1. bviengthong
    Honeycomb Jan 3, 2015
    bviengthong , Jan 3, 2015 :
    So I just got my OPO and was looking forward to beef it up with some apps. When I finally get to Amazon Prime it says its not compatible! What gives...
    Any solutions that I am unaware of?
    rhtrex likes this.
  2. tranemonk
    Froyo Jan 3, 2015
    rhtrex likes this.
  3. PatsyG
  4. bviengthong
    Unfortunately I do not use itunes.
  5. tenza978
    Cupcake Jan 3, 2015
    tenza978 , Jan 3, 2015 :
    Hopefully this isn't a problem with some of the bigger music apps too... I'm an avid listener of music and if it doesn't work properly then that takes away about 50% of what I would use it for
    bviengthong likes this.
  6. sicilian0
    Gingerbread Jan 3, 2015
  7. deejay01
    KitKat Jan 3, 2015
    deejay01 , Jan 3, 2015 :
    Google Music All Access primarily, but also have Amazon Prime. I'm on CM 12 now, but remember it did work for me on CM11S.
  8. badsqwerl
  9. rhtrex
    rhtrex , Jan 3, 2015 :
    Same here download isync app! Should work. Good luck![​IMG]
  10. Chris Haidze
    Chris Haidze , Jan 3, 2015 :
    Amazon Music works fine, and Spotify and Pandora, and Google of course. I don't think I use any others.
  11. benluca
    KitKat Jan 3, 2015
    benluca , Jan 3, 2015 :
    It IS compatible. You just have to download the Amazon app Store to your One Plus and you get Amazon Music, Amazon Photos, everything else. While you've got it, you can then take advantage of their "One free Paid app per day" as well.
  12. AnnoyingLlama
    seanamanire likes this.
  13. vdd65
    Jelly Bean Jan 3, 2015
    vdd65 , Jan 3, 2015 :
    with 64 GB, I just load my own musics and playlist. For streaming, I used Spotify and Pandora
  14. deejay01
    KitKat Jan 3, 2015
    benluca likes this.
  15. Manguman
    Manguman , Jan 3, 2015 :
    I was able to install Amazon instant video last night kind of a process. Get the Amazon app store install it from there and also install the Amazon app from there . I had found a couple of other apps that don't work with OPO downloading from the play store but did work from the Amazon app store
  16. zman7428
    Froyo Jan 3, 2015
  17. muzikman124805
    Froyo Jan 3, 2015
    muzikman124805 , Jan 3, 2015 :
    No answer that I can offer to your question. I wish I could have offered something of use other than suggesting there should have been an other option on the poll as I wanted to vote. ;) I am loving my Slacker Radio on my one day in and day out. :D Best of luck to you.
  18. bviengthong
    Are you getting crashes when opening app?
  19. zman7428
    Froyo Jan 3, 2015
    zman7428 , Jan 3, 2015 :
    I'm not. It works great.
  20. gmo8492
    Lollipop Jan 3, 2015
