not connecting to PC
  1. manishkawalia
    Cupcake Jul 6, 2017
    manishkawalia , Jul 6, 2017 :
    my oneplus 5 is not connecting to PC..its my first oneplus...i have checked the settings...my pc says usb noy recognize
    but at the same time my samsung phone is connecting bia usb to .my pc
    thanks
    mouameme likes this.
  2. Sgluskoter
    Cupcake Jul 6, 2017
    Sgluskoter , Jul 6, 2017 :
    I've had this same problem, my op5 also wasn't recognized by my computer and I'm not sure why.
  3. tzebe1
    Cupcake Jul 6, 2017
  4. mouameme
    Froyo Jul 6, 2017
    mouameme , Jul 6, 2017 :
    Same issue for me. It works with developer mode enabled with USB debugging, otherwise my W10 computer does not recognize the device. Moreover, when I switch off my computer, I have a BSOD with error "DRIVER_POWER_STATE_FAILURE".
  5. sonnyboy4u
    Cupcake Jul 6, 2017
    sonnyboy4u , Jul 6, 2017 :
    just download Windows Media feature pack for the proper version off Windows
    and enable usb debug mode in developer options on OP5 phone.
    regards Brian
  6. NahbiCris
    Jelly Bean Jul 7, 2017
    NahbiCris , Jul 7, 2017 :
    do you have Oxygen os 4.5.5? if not just wait a little that update fix this problem.
  7. Lancelot_69
    Lollipop Jul 7, 2017
    Lancelot_69 , Jul 7, 2017 :
    You are kidding right, update will not fix this
    Search won't connect to pc. 1000 threads will appear! All of them, with the exception of this one will contain the solution to your issue.
  8. jerrymilton
    jerrymilton , Jul 7, 2017 :
    there are literally a 100 threads about this already...but to cut to the chase, prior to the 4.5.5 update, one had to turn on debugging and jump thru some hoops...now w/ the 4.5.5 update...just reboot your windows computer (OP5 not plugged in)...and then plug it in (and of course change the "charging" bit to file transfer on your phone notification that appears.
    mouameme and NahbiCris like this.
  9. jerrymilton
    one doesn't have to do that anymore w/ the recent update...which is why they tell you to turn OFF debugging before updating to 4.5.5...the "bug" has been fixed.
  10. NahbiCris
  11. mouameme
    Froyo Jul 7, 2017
  12. mouameme
    Froyo Jul 7, 2017
  13. sonnyboy4u
    Cupcake Jul 8, 2017
    sonnyboy4u , Jul 8, 2017 :
    Dear Sir Lancelot
    Reckon your tone is a bit harsh....
    Take your pill and go to bed
    naughty boy...
  14. Lancelot_69
    Lollipop Jul 8, 2017
    Lancelot_69 , Jul 8, 2017 :
    Ok cupcake Pfft
