4
not happy with adaptive brightness/ auto brightness
  1. TarveshChauhan
    Froyo Aug 16, 2019
    TarveshChauhan , Aug 16, 2019 :
    its been 1 month i m using oneplus 7 .... the problem i m facing is adaptive brightness . its not working properly or smoothly . as i was using iphone previously the autobrightness was perfectly balanced and works very fine.
    this is request tobyou oneplus team plz work on this asap
    because its very irritating.
  2. Madnezz4Ever
    Jelly Bean Aug 16, 2019
    Madnezz4Ever , Aug 16, 2019 :
    No one here is from OnePlus and you can turn off adaptive brightness if you have an issue with it.
    Adaptive brightness has to learn, so you have to manually adjust it.
    Your better off turning it off and manually adjusting it.
    Pressing the sun icon turns it off.
  3. TarveshChauhan
    Froyo Aug 16, 2019
    nobody is from oneplus [e]1f622[/e]
    why to turn off if this features has been given to use .
    better to improve it .
    Vinay_ likes this.
  4. Madnezz4Ever
    TarveshChauhan
    better to improve it .​
    Because you're having an issue with it? You have to teach it by manually adjusting it, which is probably why you are having issues.
    If you want it improved, then you should be bugging Google as it's a feature of Android not OnePlus.
  5. Starcommander
    KitKat Aug 16, 2019
    Starcommander , Aug 16, 2019 :
    Keep on adjusting the brightness according to your need. It takes about a week to learn your pattern for apps and adapts accordingly.
  6. TarveshChauhan
    Froyo Aug 17, 2019
    TarveshChauhan , Aug 17, 2019 :
    Madnezz4Ever
    TarveshChauhan
    If you want it improved, then you should be bugging Google as it's a feature of Android not OnePlus.​
    bro your suggestion is upto the mark ..but everytime compromisng is not the solution... we should correct it .
    hahah bro its not only Google its manufacturer also who can do this.
    anyways i find u negative . cheers
    Vinay_ likes this.
  7. TarveshChauhan
    Froyo Aug 17, 2019
    ok thanks brother
    Starcommander likes this.
  8. G_Omar_Balboul_mzxz
    Cupcake Aug 24, 2019
    G_Omar_Balboul_mzxz , Aug 24, 2019 :
    The adaptative brightness was working very well on m'y oneplus 3t, but on oneplus 7, its very slow and réponds too late
    Vinay_ and harsh1682 like this.
  9. K1565907639277
    Cupcake Aug 25, 2019
    K1565907639277 , Aug 25, 2019 :
    I have use mi note 5 pro and Poco before switching to one plus 7 since it was irritated of mi unnecessary ads and free apps which installed cani be reversed.but mi phone auto brightness is way better than one plus 7, also selfi photo are reddish.. don't know how to fix it
  10. harsh1682
    Froyo Aug 27, 2019
    harsh1682 , Aug 27, 2019 :
    Same here..!! not happy with how it performing.. the brightness sometimes does not even adjusts itself in sunlight and in the dark too... m running on OOS 9.5.8.. OnePlus 7
