Can anyone help, I am not receiving incoming calls on my one+8t. Took some time to realise this but have done some investigation and there is something very odd going on.
If I am on Instagram I do not receive incoming calls, however if I force stop Instagram I appear to then be able to receive calls. Has anyone ever seen this before? Maybe its some funny setting?
Worth mentioning this was a brand new phone that had to be sent back straight away cause the mobile network wouldn't connect. This was fixed but now not receiving calls when certain apps are on seems very odd.
Android version 11
Oxygen OS 11.0.6.9
Edit: resolution for me as mentioned in below replies
We are in Ireland and using the 3 network, the default settings on the phone for preferred network type is 2g/3g/4g/5g (default) which enables another 5g setting. I changed this to be 2g/3g/4g (default) which removed 5g. I am guessing the networks here are not up and running in terms of 5g and this is some how effecting network connection on the phone.
Go to settings -> WiFi and internet -> SIM and network -> preferred network type -> set 2g/3g/4g (default)
Hi,
I am using the OP 8t with 3 network Ireland and having the same issue the last month or more!! Is it phone, network or both.??
