Not responsive for couple of seconds and battery backup toooooo low Driving me nutsss....
  1. B1527431838214
    Cupcake Oct 15, 2018
    B1527431838214 , Oct 15, 2018 :
    Not responsive for couple of seconds and battery backup toooooo low Driving me nutsss.... feeling frustrating after moving to Android P.....
    please take corrective action soon.... not sure why you are delaying soo much time ever after hearing the issue long back. Don't make users loose their coolness
  2. B_Wrath
    Nougat Oct 15, 2018
    B_Wrath , Oct 15, 2018 :
    On a serious note, you didn't give any detail on either your unresponsive phone and battery usage..
    Nobody can help you with just your ranting...
    Artemus. and B1527431838214 like this.
  3. B1527431838214
    Thank you for your kind reply,
    coming to responsiveness, touch stops responding or any operation for that matter delays by couple of seconds... apps won't respond.... as if like very old phone with no memory, v v low ram sort of response.... have enough memory and free ram in my one plus 6.
    coming to battery, used to get more than a day to 2 days which is around 4 hours of screen time... now hardly gets 3/4. of a day... almost around 3 hrs of screen.... eventhough nothing change in my usage.
    let me know if you need more info.
  4. B_Wrath
    Nougat Oct 15, 2018
    Post your battery stats and graph...
  5. B1527431838214
    just 100% charged... need to wait till for Lil time... , unfortunately can't go to previous history....
  6. B_Wrath
    Nougat Oct 15, 2018
    Alright... And for your unresponsive touches, does it happen randomly or is there a pattern?? Does it happen only in few apps???
  7. B1527431838214
    observed.... didn't find any pattern..:(, so the reason to post
  8. B_Wrath
    Nougat Oct 15, 2018
    The only solution i can give you is, do a factory reset... It will clear all your issues...
    Artemus. likes this.
  9. B1527431838214
    hmmm.... sry... looking for different solution if possible... don't want to go through data transfer... frustrating process...
  10. B_Wrath
    Nougat Oct 15, 2018
    But that's the best solution... Anyways... If it is cumbersome for you, next time, try to identify any pattern or apps which cause unresponsiveness....
