Battery/Charging Not Showing Usage Data
  1. Kartikay Malo
    Cupcake Aug 10, 2020
    Kartikay Malo , Aug 10, 2020 :
    Hi Guys,
    I started using OnePlus 7 Pro from December 2019 and I get updates as a BETA tester.
    Whenever I am trying access the detailed battery usage after charging, it is resetting again and again, and old data get deleted which was not the case earlier. It shows detailed batter usage isn't available.
    Is this problem alright or do I need to do something to get it right?
  2. drl431
    Nougat Aug 10, 2020
    drl431 , Aug 10, 2020 :
    Hi, its normal for the battery usage data to be reset each time the battery is recharged (reaches at least 90%).
