Not used dash charger for nearly a year
  1. Sandwiches
    Honeycomb Feb 8, 2018
    Sandwiches , Feb 8, 2018 :
    hi,
    I've been using a samsung 2a usb charger for nearly a year as I lost my oneplus 3 dash charger.
    Will this have done any damage to my battery?
  2. G_sambba1230_hgKz
    Cupcake Feb 8, 2018
  3. Silviu094
    Gingerbread Feb 8, 2018
    Silviu094 , Feb 8, 2018 :
    I am doing this too, as I don't have a dash charger. The device is cold while charging, I don't even get dash charging. Should there be any problems?
  4. robinevers
    Tapan Kumar, 9qu, mariogold42 and 2 others like this.
  5. VaibhavBhargava
    Lollipop Feb 8, 2018
    VaibhavBhargava , Feb 8, 2018 :
    No, there should not be any problems. But, if possible try to use the stock charger.
    mariogold42, Silviu094 and Sun90 like this.
  6. hugoaferreira
    hugoaferreira , Feb 8, 2018 :
    Lol. Bottom line: you never use one of the best assets of your device. Not very smart as far as I know.
  7. shaoxia
    Cupcake Feb 8, 2018
  8. Silviu094
    gonna buy one soon. not finding good cable in my region so I think I will end up buying from the official site
  9. arminth
    arminth , Feb 8, 2018 :
    Dash charge only works with official cable!
    Cheers
    Armin
  10. YehudaGo
    YehudaGo , Feb 8, 2018 :
    it won't do any damage to your battery, may be even better because you don't stretch the battery on charging.
    but you don't get the full oneplus experience with fast charging
  11. V1518085917724
    Cupcake Feb 8, 2018
  12. Sam Nakamura
    Ice Cream Sandwich Feb 8, 2018
    Sam Nakamura , Feb 8, 2018 :
    No, that's not true, it's about the wall plug not about the cable, I use a 2 meter 3rd party cable at work with the original dash wall plug and it reliable dash charges every time... Some cables may be incompatible though
  13. YehudaGo
    check your phone if you get real dash charging logo and fast charging time, because the oneplus cable use the usb 3 added pins for dash charging, and most of the cables don't have it .
    https://forums.oneplus.net/threads/...-a-f-cable-supports-op3-dash-charging.454306/
  14. Sam Nakamura
  15. Silviu094
    ordered the charger, waiting to see if it works with my cable, if not I will order a cable too
  16. zeetheali
    zeetheali , Feb 8, 2018 :
    Dash charger is designed for OP devices. So if you lost then buy new one. And enjoy its Dash feature. I think its tasteless to use OP Dash supported devices without Dash Charge.
  17. MarkyPancake
    MarkyPancake , Feb 8, 2018 :
    I fail to see how slow charging using an appropriate power output will affect the life of the battery compared to constantly fast charging it. Shouldn't slow charging at an appropriate power output actually prolong the battery life.
  18. idkwhoiam322
    Nougat Feb 8, 2018
    idkwhoiam322 , Feb 8, 2018 :
    Don't mislead.
    It shouldn't harm the battery in any way, but you're not using all the capabilities of the device though...
  19. Sandwiches
    never missed it though, phone always has 10-15% before bed, what's the point in dash charge if I charge it when I'm asleep?
    looks like not using dash charge has prolonged my battery health then? sounds smart to me.
  20. hugoaferreira
    The thing is that you don't need longer to charge your phone. With dash charge in one hour the battery is full. My post was not meant to offend you. If it did, then I'm sorry.
