[Submitted] Not usimg tele lens when zoomimg
  1. QTreiber
    Cupcake Jul 5, 2017
    QTreiber , Jul 5, 2017 :
    When using the stock photo app it's always using the normal lens.
  2. QTreiber
    Cupcake Jul 18, 2017
  3. mobil-man
    Donut Jul 18, 2017
    mobil-man , Jul 18, 2017 :
    If you cover the 1,6x zoom lens, then camera use primary 1x lens and you can see flashing (camera try to change to 1,6x). Which lens captured picture is in EXIF data (f1,7 for 1x or f2,6 for 1,6x). On the other hand try to cover 1x camera lens, change to 2x zoom, uncover camera and cover again. The picture should be same clear (because input will be only from 1,6x camera).
  4. QTreiber
    QTreiber , Jul 18, 2017 :
    OK, thanks for your answer. I think it's using the 1,6x lens sometimes. For me it's not logical that it useses sometimes the 1x lens and sometimes the 1,6x lens when zooming 2x.
    Picture 1:
    1x with f1,7: https://photos.app.goo.gl/OejtNe8mZtPjsBfz1
    2x with f1,7: https://photos.app.goo.gl/izo8hei2jO4f3CYb2
    Picture 2:
    1x with f1,7: https://photos.app.goo.gl/gUGtm9YXIfypbxQv2
    2x with f2,6: https://photos.app.goo.gl/Xe5J9oWUMec1wNYf1
    I think it would be nice, if you can select which lens is used (at least in pro mode) anyway.
  5. mobil-man
    Donut Jul 19, 2017
