Answered notch display changed
  1. P1582789746532
    Cupcake Feb 27, 2020
    P1582789746532 , Feb 27, 2020 :
    hello, wasn't sure where else to go so figured here was fine. I recently got an update on my oneplus 6t and it changed the notch display. it used to be where I could make it black background so everything was the default display size but my status bar was like a seperated tab that contrasted and was not transparent. just wondering if I can fix this. thanks!
  2. Gav_W86
    Starting Point Expert Feb 27, 2020
    Gav_W86 , Feb 27, 2020 :
    the change in behaviour is apparently by design, you can put feedback direct to OnePlus via Feedback feature in the OnePlus Community app (tap the red + button and select Feedback).
  3. P1582789746532
    thanks for you help!
