2
Notification bubbles do not work on Oneplus 7 Android 11 Stable via OnePlus 7
  1. U1562855622185
    Eclair Apr 15, 2021
    U1562855622185 , via OnePlus 7 , Apr 15, 2021 :
    Notification bubbles do not work on Oneplus 7 EU. It just worked only the first time I received a notification (Telegram) after updating to Android 11, but it did not work again.
    I have tried to enable and disable the option, check if apps have access to bubbles, multiple reboots, several wipe cache... And nothing fixed it.
    Every time I receive a notification (from a compatible app like Telegram), a button for opening the chat in a bubble appears, but nothing happens if I press it.
    Does this happen in Open Beta 4? Will be fixed? Thanks
    AGuser and Karlo0077 like this.
  2. Karlo0077
    Cupcake Apr 15, 2021
  3. drmartin
    Moderator Moderator Apr 15, 2021
  4. AGuser
    Froyo Apr 17, 2021
  5. AGuser
    Froyo Apr 17, 2021
  6. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 17, 2021
    Dresa91 , Apr 17, 2021 :
    Did you clear cache of Telegram?
    Did you re-enable the bubbles?
    Bobbie63 likes this.
  7. U1562855622185
    Eclair Apr 17, 2021
    U1562855622185 , via OnePlus 7 , Apr 17, 2021 :
    Yes, I have just done it again to be sure. These steps:
    - Clear Telegram cache from Oneplus' settings app
    - Disable bubbles for all apps
    - Restart phone
    - Enable bubbles
    When bubbles were disabled, Telegram notifications did not show the "open in bubble button". And, when I enabled them, this button came back, but still did not work.
  8. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 18, 2021
    Dresa91 , Apr 18, 2021 :
    Did you submit a bug report via https://forums.oneplus.com/feedback?
  9. U1562855622185
    Eclair Apr 18, 2021
  10. Dresa91
    What do you mean with you didn’t have the link?
  11. U1562855622185
    Eclair Apr 18, 2021
    U1562855622185 , via OnePlus 7 , Apr 18, 2021 :
    Sorry. I mean that I did not found the "submit bug" link before you gave to me. Now, with that link, I have submitted it.
  12. Dresa91
    Ah okay :)
  13. U1562855622185
    Eclair Apr 19, 2021
  14. Dresa91
    User of the Year 2016; Most Active User 2020 Apr 19, 2021
    Dresa91 , Apr 19, 2021 :
    Did you submit a bug report and did you contact the devs of Telegram?
  15. U1562855622185
    Eclair Apr 19, 2021
    U1562855622185 , via OnePlus 7 , Apr 19, 2021 :
    It's solved. It must have been a telegram bug. Here is what I have done:
    First of all, yes, I submitted the bug in OnePlus website, and I was contacted asking me for device log, but I didn't know how to follow the steps because there some buttons that did not exist. I asked them about that (I think UI has changed, because their description did not match with I was seeing on screen) and they have not responded yet.
    Later, while I was waiting for any reply from OnePlus support/devs, I checked if this bug happens on others app (I installed Google Messages app, and waited for a SMS message). It worked, the bubble opened perfectly and multiple times, no only the 1st time.
    So, I assumed that the problem was maybe in Telegram app and not in Oxygen OS. I was going to report this bug on their website and, while I was filling the form, it (the "report bug" bot) detected that I was using an outdated app version (but I had checked Google Play and there was no update available), so, I uninstalled the app and installed the new Telegram app (downloading the apk directly from their website) and when I received a new Telegram notification, I could open it as a bubble. I repeated this several times and now it works perfectly.
    I think this might be a bug of Telegram's Google Play version, and perhaps I will be fixed soon.
    Thanks a lot for your help!!
    Dresa91 and Bobbie63 like this.
  16. Dresa91
    Great that it is solved:)
    You are welcome:)
  17. cr1411
    Froyo Apr 19, 2021
  18. #18
  19. Louisbaecke510
    Honeycomb Apr 20, 2021
    Louisbaecke510 , Apr 20, 2021 :
    you must turn in on in the apps him self i got this issue too
  20. U1562855622185
    Eclair Apr 20, 2021
    U1562855622185 , via OnePlus 7 , Apr 20, 2021 :
    I would think so except that the first notification I received after upgrading to Android 11 I was able to open it as a bubble perfectly. After that, I couldn't open any Telegram notification in a bubble. The "open in bubble" button did nothing, just changes its icon.
