Notification issues via OnePlus Nord
  1. Onnux
    Eclair Jan 24, 2021
    Urcan likes this.
  2. H.S.S
    Honeycomb Jan 24, 2021
  3. PritishPriyam
  4. Urcan
    Froyo Jan 24, 2021
    R1611541913606 likes this.
  5. R1611541913606
    Cupcake Jan 25, 2021
    R1611541913606 , Jan 25, 2021 :
    Glad to hear that
    Any idea when the general version to be released?
  6. Onnux
    Eclair Jan 25, 2021
    Onnux , via OnePlus Nord , Jan 25, 2021 :
    When I am update oxygen os11 open beta 2 the same issues will be not solved
    Urcan likes this.
  7. R1611541913606
    I facing same issue too
    This problem happened mostly during in WiFi
    The notification works pretty well during in 4g
    Besides, I'm suspecting the wifi is going "hibernate" while your screen is locked.
    For example, the whatsapp web is disconnected after some time of screen locked.
    As you all may know that, whatsapp web can only be used with your phone having active internet connection.
    Please advise.
  8. Urcan
    Froyo Jan 25, 2021
    Urcan , via OnePlus Nord , Jan 25, 2021 :
    I also have this problem but only in these conditions: wifi connection with IPv6 enabled and screen in standby. to solve i manually set ipv4
  9. R1611541913606
    Cupcake Feb 7, 2021
    R1611541913606 , via OnePlus Nord , Feb 7, 2021 :
    Hi guys
    I found a solution that 100% work!
    Please use wifi with vpn activated
    With vpn, WiFi will not get disconnected when phone locked
    (Note: beforehand, you need to download a vpn apps from play store. I do recommend "vpn proxy master")
    So far this is the best temporary solution as of now before
    Oxygen OS 11 release.
    Guys please try and let me know if its work!
