3
Notification LED Apps
  1. Fuschy
    Gingerbread Jun 2, 2019
    Fuschy , Jun 2, 2019 :
    Hey guys,
    so the only thing Im missing on my OP7 Pro is the notification LED.
    Are there apps, that let me customize the standard blue notification edge light?
    For example where I can make that blue light for Whatsapp green and have it flash every x seconds. Just like a LED would do?
    Thanks in advance.
    sabatinodm, ben.pyett and tebsoo like this.
  2. akks
    KitKat Jun 2, 2019
    akks , Jun 2, 2019 :
    Hopefully that'll be done by OnePlus itself in coming updates. Reasonably high demand, as per their track record, OnePlus usually does something for their customers. Stay fingers crossed!
    As of now, third party apps, I'm not sure.. Sorry
  3. Matt 80
    Lollipop Jun 2, 2019
  4. bicho_zgz
    Donut Jun 2, 2019
    bicho_zgz , Jun 2, 2019 :
    I have installed this app but I see it appears among the app that consumes the most energy of the battery. And Tenho set so that the brightness is at a minimum and that it only comes on when I receive a notification.
    How is it going to you in battery consumption?
    Best Best regards.
  5. ben.pyett
    Eclair Jun 2, 2019
  6. Blackbird511
    Eclair Jun 3, 2019
  7. Maverick2.0
    KitKat Jun 3, 2019
    Maverick2.0 , Jun 3, 2019 :
    But what about the battery drain? I have the OnePlus 6, so I don't need any notification led app. However, this app is great for AoD feature. So how much battery do you lose?
  8. Blackbird511
    Eclair Jun 3, 2019
    Blackbird511 , Jun 3, 2019 :
    Honestly I can't tell any difference.
    I'm not the kind of person that watches all that shite.
    I will tell you that I go 90% of the day with regular use without having to charge it.
    Maverick2.0 likes this.
  9. Maverick2.0
    KitKat Jun 3, 2019
    Are you using the Glance feature where the screen comes on only when there is a notification? Or are you using it as proper always on display?
  10. Blackbird511
    Eclair Jun 3, 2019
    I have it set to always on.
    Edge light notification for 30 sec.
    I've set the brightness to around 20 or so.
    Battery remaining icon on.
    Battery charging on.
    And double tap to wake or sleep.
  11. Maverick2.0
    KitKat Jun 3, 2019
    If you have it always on, then how would you set double tap to wake? The screen is on all the time.
  12. Blackbird511
    Eclair Jun 3, 2019
    I mean when I double tap on the AOD screen I get immediately brought to my fingerprint lockscreen.
  13. Maverick2.0
    KitKat Jun 3, 2019
    Are you a light user or a moderate one?
    And how much battery do you have left after say 12 hours ( a whole day basically)?
  14. Maverick2.0
    KitKat Jun 3, 2019
    Ok. Got it. I too had that set. I love the app, purchased it too. But unsure about the battery drain trade-off.
    One big problem with the app while using the 6 is that the Notification LED doesn't work with the app enabled.
    Blackbird511 likes this.
  15. Blackbird511
    Eclair Jun 3, 2019
    I'm moderate to heavy.
    From 5:30 am I'm good till 4pm.
    Some days I might have to give it a charge around 2pm.
    Been like that since day 1 with this device.
  16. Blackbird511
    Eclair Jun 3, 2019
    Never owned the 6.
    Only had the 6t and th 7 pro.
    So I haven't had a notification light in a while.. Lol
    I love this app as well!
  17. Blackbird511
    Eclair Jun 3, 2019
  18. Maverick2.0
    KitKat Jun 3, 2019
    I think you are getting losing less battery because of the SD 855 SOC.
    However, I wouldn't mind a 10 - 11 hour battery life if I get that with AoD on.
  19. Maverick2.0
    KitKat Jun 3, 2019
    Actually, I didn't tinker with it at all. I am trying to figure out if I can have the AoD on all the time and still get 12 hours or so. That would be fine by me.
    Let me check about the edge thing and get back to you.
    But aren't you worried about the edge lighting harming the display and also affecting battery life?
  20. Blackbird511
    Eclair Jun 3, 2019
    Harming the display?
    You mean as far as screen burn?
    If so, I wouldn't want the edge notification to constantly going off. But say to cycle. 15 seconds on. 30 seconds off. Then repeat.
    I'm truly not worried about battery life. I have chargers at each place I'm at throughout the day if need be.
