2
Notification Led not working in Nougat
  1. MarkelIglesias Eclair Jan 3, 2017
    kylesweet and HIT-199 like this.
  2. kprethish Cupcake Jan 3, 2017
  3. HIT-199 Honeycomb Jan 3, 2017
    HIT-199, Jan 3, 2017 :
    I have the same problem. I checked every setting and also installed a few apps new but nothing helps. So I think we have to wait for an update - for the apps and for the system... :/
    MarkelIglesias and imam88 like this.
  4. MarkelIglesias Eclair Jan 3, 2017
    MarkelIglesias, Jan 3, 2017 :
    Yes ,I checked the settings and I have turn on the notification leed...but nothing..
  5. seelapureddy kishanreddy Eclair Jan 3, 2017
  6. cexak Cupcake Jan 3, 2017
    cexak, Jan 3, 2017 :
    The notification led is only working if sound notification is turned on for the app.
    Ex. i use Whatsapp and have no sound signal on for Whatsapp, only led. It does not work. The led will not go on untill i assign a sound to Whatsapp. Same with Bluemail. I don´t want a sound, just the led notification. But doesn´t work anymore. Did work before the Nougat update.
    kylesweet, vuvuxela and mockabar like this.
  7. HIT-199 Honeycomb Jan 3, 2017
    Do you know if the app developer or oneplus has to fix it? Cause I also want that I get just the led notification.
  8. dannyaeng Donut Jan 3, 2017
  9. davidcogman Cupcake Jan 10, 2017
    davidcogman, Jan 10, 2017 :
    Similar issue here - no LED notifications working since the upgrade. Tried everything. LED itself is fine - it's on when charging
    Jatin Madaan likes this.
  10. Shrinathraman Cupcake Jan 10, 2017
    Shrinathraman, Jan 10, 2017 :
    Was it worked well before the update???
    Had you dropped your mobile??
    Whether your mobile got water splashed on it??
    Tried resetting your device??
  11. davidcogman Cupcake Jan 10, 2017
    Shrinathraman likes this.
  12. anujpant08 Cupcake Jan 10, 2017
  13. davidcogman Cupcake Jan 10, 2017
  14. malekbogra Cupcake Jan 10, 2017
  15. Lugusto Cupcake Jan 23, 2017
    Lugusto, Jan 23, 2017 :
    I have the same problem - it's a bug. If you set the notification tone in the app to anything other than 'None' (i.e. make a sound) the LED will work. If the notification tone in the app is set to 'None' the LED will not work now, before Nougat this wasn't an issue.
  16. Lokesh kumar@324 Eclair Jan 23, 2017
  17. F_Ryan_James_Dunn_lMvu Cupcake Jan 23, 2017
    F_Ryan_James_Dunn_lMvu, Jan 23, 2017 :
    there was a post with a lot of fixes to all the common issues people have been having posted recently. instead sure there was something about the above issue with the LED in there [e]1f44d[/e]
  18. mariano666 Donut Jan 29, 2017
    mariano666, Jan 29, 2017 :
    For what I've seen if you do not choose a sound for a notification on whatsapp LED doesn´t work. Individual LED notifications weren´t working, so I chose no sound, no LED, then go back to a sound and a LED color and it worked. When I tried the same with groups, it didn´t. The only thing that applies LED notifications to groups is adding a sound (Notification sound for groups for me is Silent, so no sound)
  19. Zh_kilat Android Q Jan 29, 2017
  20. saranshdikshit Cupcake Feb 7, 2017
    saranshdikshit, Feb 7, 2017 :
    I am experiencing the same thing. My led notifications are on for all the apps but the led doesnt light up for specific apps like whatsapp or sms service. The nougat update seems to be a bit buggy at the moment. I guess we can only wait.
