Notification led
  1. Noel Mathews
    Eclair Sep 1, 2019
    Noel Mathews , Sep 1, 2019 :
    Hi everyone,
    Are there any 3rd party application that can show led notification for all types of msgs/call etc? I've tried the plus beat app as suggested by others, but to no avail.
    Any other suggestions or work around for this?
    Thanks in advance.
  2. saiz136
    Froyo Sep 1, 2019
    saiz136 , Sep 1, 2019 :
    I don't use them since getting 3rd party apps will drain your battery a lot rather than stock / built-in. I hope they can add Always On Display in Android 10.
    Alby71 and Noel Mathews like this.
  3. Noel Mathews
    Eclair Sep 1, 2019
    sure hope they do add this function in a future update.
    saiz136 likes this.
  4. Melkuse Daniel
    Gingerbread Sep 1, 2019
  5. Noel Mathews
    Eclair Sep 1, 2019
  6. Melkuse Daniel
    Melkuse Daniel , Sep 1, 2019 :
    Yes bro, I m also a OnePlus 7 pro user, I have tried it in my my OnePlus 7 pro device it worked pretty well, I hope it will work on yours too, let me know whether it works on your device...
    Noel Mathews likes this.
  7. Noel Mathews
    Eclair Sep 1, 2019
    will try it out asap and let u know. Cheers :)
  8. Melkuse Daniel
  9. Noel Mathews
    Eclair Sep 1, 2019
    I've just tried it out and it works perfectly! Thanks so much for the recommendation. How does it affect battery life?
  10. Melkuse Daniel
    Glad to hear that from you, don't worry about the battery life, you will get the same battery backup as you are getting now(in my case I got the same screen on time as before and after installing it), I hope you also get the same, but in case if it differs let me know. Cheers...
  11. Noel Mathews
    Eclair Sep 11, 2019
    Noel Mathews , Sep 11, 2019 :
    Hi guys, Just an update...used the Notify Buddy app for over a week, it worked perfectly but the battery life took a HIT! i was getting only around 40% towards the end of my workday and it was the sole app taking as much as 15% as stated on the battery usage stats....sadly had to uninstall it. Now, battery life is back to normal.
  12. blackvoske
    Eclair Sep 11, 2019
    blackvoske , Sep 11, 2019 :
    Yep, noticed that too, the app's don;t do it for me.
  13. Noel Mathews
    Eclair Sep 11, 2019
    blackvoske
    Yep, noticed that too, the app's don;t do it for me.​
    this should be an easy fix, OnePlus should've just included this as an option with the ambient display setting :/
    cucuros and blackvoske like this.
