5
Notification LED via OnePlus 8T
  1. DutchDanny
    Eclair Nov 1, 2020
    DutchDanny , via OnePlus 8T , Nov 1, 2020 :
    I noticed when I unlock my phone it has an notification LED simulation.
    First it makes a a circle around the camera and then a led dot simulation.
    Are there settings for this option and why does this led only show on wake-up and not on a locked screen?
  2. Does!Compute
    KitKat Nov 1, 2020
    Does!Compute , Nov 1, 2020 :
    You must have enabled face unlock. That animation is used to show that the front camera is being used. The same is observed while using the front camera in the camera app
    McJader, Tokolozi, puccellino and 2 others like this.
  3. DutchDanny
    Eclair Nov 1, 2020
  4. Does!Compute
    KitKat Nov 1, 2020
    They are working on that. The idea has been accepted in Ideas 2.0 campaign
  5. tokektokek
    Gingerbread Nov 1, 2020
    tokektokek , Nov 1, 2020 :
    That is great news - I upgraded from the OnePlus 5 to the 8T, and was very surprised and disappointed to see that a notification light was missing 8T. It is one of the most useful things on a phone - something you would expect a phone to have - and I couldn't understand why the 8T was missing something that the 5 had.
  6. Does!Compute
    KitKat Nov 1, 2020
    The feature isn't present on the 8T due to the extremely small bezel size. It is difficult to fit in an LED there.
    McJader and Tokolozi like this.
  7. tokektokek
    I definitely would prefer to have a bigger bezel than no notification light. Or possibly the LED could be fitted in screen, like the front facing camera, but on the other side
  8. Does!Compute
    KitKat Nov 1, 2020
    Like 2 punch holes? (Noooooooo)
    Tokolozi likes this.
  9. DailyLama72
    Froyo Nov 2, 2020
    DailyLama72 , Nov 2, 2020 :
    That might be true, but then why no solution like Notify Buddy that simulates a LED?
    Whatever solution, to have a phone lying dead like a brick while several mails and messages are waiting seems to be the worst choice you can make.
  10. Scherpenseel
    KitKat Nov 2, 2020
    Scherpenseel , Nov 2, 2020 :
    Do you have a source?
  11. Does!Compute
    KitKat Nov 2, 2020
    Does!Compute , Nov 2, 2020 :
    Check the ideas 2.0 section of the forum
  12. Does!Compute
    KitKat Nov 2, 2020
    Use AOD?
  13. tokektokek
    Gingerbread Nov 2, 2020
    tokektokek , Nov 2, 2020 :
    AOD is ok, but not for notifications. What is needed on the 8T is a light that flashes when you get a notification, and keeps flashing until you have seen the notification, it can also be used for charging so is red when charging and then green when charged. The OnePlus 5 had a notification light, for the OnePlus 8T it is almost like it was forgotten
  14. X1603141720046
    Honeycomb Nov 3, 2020
    Scherpenseel likes this.
  15. magic2feet
    Eclair Feb 3, 2021
    magic2feet , via OnePlus 6 , Feb 3, 2021 :
    I was due to upgrade from my op6 last year but decided to hold off because of this notification led nonsense. I think one plus and others(Samsung) are forgetting that these devices are actually phones. The led is truly an essential little piece of the puzzle.
  16. I1510079585943
    Cupcake Jul 24, 2021
    I1510079585943 , Jul 24, 2021 :
    Hey any clue in which update it will come ? I have latest OOS version installed in my Oneplus 8 which is 11.0.7.7
  17. MrBender
    MrBender , Jul 24, 2021 :
    Hey,
    Any further information about the implementation?
    AOD is not good for real time notification.
    I came from a 5T and the led notification is essencial.
    There are option like install apk notifications but they drain the battery.
    When will be this option implemented?
    Shaun_the_sheep likes this.
  18. #18
  19. McJader
    Marshmallow Jul 29, 2021
    McJader , Jul 29, 2021 :
    Whenever OPPO overlords decide to, now that the codebase is integrated.
    banandhi likes this.
