2
Notification Light in 7T Pro McLaren Edition via OnePlus 7T Pro
  1. bilboroy
    Cupcake Dec 3, 2019
    bilboroy , via OnePlus 7T Pro , Dec 3, 2019 :
    In case of a Notification, If the horizontal notification light blinks only once, and for later it doesn't gives us an alert, what's the use of it even ?
    My former phone, OP 5 is much better in terms of this. Atleast it alerts me in case of a Notification, with a constant blinking light.
    Its understandable that if the notification light blinks constantly l, it will consume a load of battery during standby.
    a solution for that can be, when the notification arrives, it gives a very wide zap of light. But for later part, for constant blinking, simple thin lines blinking on the sides or just running through the edges constantly, just to make us understand that there is a notification, can be helpful.
    Wide edge light can consume a lot of battery, but a thin line can help it.
    @OnePlus, Kindly look into this and give a fix for this.
    Nickname and pavan_0050 like this.
