4
Display Notification Light not working for OnePlus 6
  1. rikg09
    Donut May 26, 2018
    rikg09 , May 26, 2018 :
    Hey guys, not sure if I'm just being stupid or something, but I'm not getting the notification for the LED light when I have a message/whatever.
    Dash charge comes up as blue, and normal charging as red, so the LEDs are working.
    I've allowed all apps to send notifications, and allowed Pulse Notification light in the display settings. I've made the default light for apps to be Purple, but it doesn't come up.
    Really annoying, since I've just upgraded from the OnePlus 3, where this was all working fine.
    So am I being stupid? Or is this an issue? Or ....what?
  2. G_Avee_B_Xaxb
    Jelly Bean May 26, 2018
    G_Avee_B_Xaxb , May 26, 2018 :
    that is what OOS is, i spent 3yrs on emui and 2yrs in galaxy phone but barely have had OS/UI problems,,,, 1.5 yrs with OOS encountered many issues though it is fixed by factory reset.
  3. Kalle81
    KitKat May 26, 2018
  4. hypercode
    Froyo May 26, 2018
    hypercode , May 26, 2018 :
    This option does not exist
  5. Kalle81
    KitKat May 26, 2018
  6. hypercode
    Froyo May 26, 2018
  7. hypercode
    Froyo May 26, 2018
    Actually the apps set their notification color, if there isn't an option in the apps, the OS uses default color that set in the settings. Then probably your issue is an app issue.
  8. PedroCabarga
    Cupcake May 27, 2018
    PedroCabarga , May 27, 2018 :
    I have a one plus 6
    and I have the problem that the applications that can not be selected the color of the LED in themselves, does not notify you any color the led
    by default it says that it gives you a default color (green) but does not notify any
  9. PedroCabarga
  10. darkn3xx
    Donut May 27, 2018
    darkn3xx , May 27, 2018 :
    I have noticed the same issue. I use mainly Google Allo for texting and the notification dot does not work. Even after reboot or by reinstalling the app -> no chance to get it work :(
  11. 404.php
    Honeycomb May 27, 2018
    404.php , May 27, 2018 :
    Works for me. The light is located in the notch. I wonder if it's being blocked on your phone.
  12. rikg09
    Donut May 29, 2018
    Best Answer
    rikg09 , May 29, 2018 :
    Hey guys, I got fed up in the end and did a hard reset. Works now, although I feel like my LED on my OP3 was brighter....
    I'm assuming this can't be made brighter though so ah well
  13. Bollux
    Gingerbread May 29, 2018
    Bollux , May 29, 2018 :
    No problem here, im getting notification light on Facebook and WhatsApp
  14. PedroCabarga
    Cupcake May 31, 2018
    PedroCabarga , May 31, 2018 :
    Effectively, Facebook and WhatsApp notifications if the led works, but all the other Apk do not turn on the led
    that's the problem
  15. rikg09
    Donut Jun 1, 2018
    rikg09 , Jun 1, 2018 :
    Ahhh crap. Didn't even notice that...
    Do OnePlus know? Or is this an issue thats just been raised?
  16. Shaharukh JP
    Cupcake Jun 1, 2018
    Shaharukh JP , Jun 1, 2018 :
    Hi, On my OnePlus 6 I'm having this weird issue with notification LED. I have set my charging battery color to Orange but when I plug in the charger for 2 second it shows orange and then it turns blue. (Default LED color is set to blue) also for notification by messenger, WhatsApp and other should show default notification light that is blue but it shows white LED light.
    Please help.
  17. SohamSG
    Froyo Jun 2, 2018
  18. patrickpoon
    Cupcake Jun 2, 2018
    patrickpoon , Jun 2, 2018 :
    For your info, Dash charge is always showing blue.
  19. Shaharukh JP
    Cupcake Jun 2, 2018
    Shaharukh JP , Jun 2, 2018 :
    what about other issue with WhatsApp and other messenger.
    hard reset is not an option for me.
  20. patrickpoon
    Cupcake Jun 2, 2018
    Fortunately, LED and everything is fine at the moment.
