Notification light while charge and lock scree photo option
  1. Aravind246 Donut May 25, 2018
    Aravind246, May 25, 2018 :
    Hi,
    While charging my OnePlus 6 the notification light should be in red color(I changed in display settings already) but for me it is blue color. is there similar issue for anyone??
    Another one is when I open any photo and select set as option I can't be to see lock screen option in OnePlus 6.
    Is this for everyone or any problem with my settings??
  2. JamieeTime Eclair May 25, 2018
    JamieeTime, May 25, 2018 :
    1) LED notification light is blue when dash charging, red when normal charging
    2) To set lock screen wallpaper on OP6 you must:
    Select the photo you wish to set as your lock screen
    Press 'set as'
    Press wallpaper (not home screen wallpaper)
    You are given an opportunity to edit the photo at this point
    Finally, press 'apply' in the top right corner then you will be given the option to set as home screen, lock screen or both.
    Hope this helped [e]1f601[/e]
    MentalDraco and Aravind246 like this.
  3. Aravind246 Donut May 25, 2018
    Thanks allot... Now got it... Thanks for comment.
    JamieeTime likes this.
