3
notification problem in Instagram
  1. Abhishek4441
    Froyo May 22, 2017
  2. Android450
    Marshmallow May 22, 2017
    ghostofcain and Heisenberg_009 like this.
  3. hedwigy
    Eclair May 22, 2017
    hedwigy , May 22, 2017 :
    No that's not the solution. the solution is to turn off the disable app auto launch in app settings.
  4. Android450
    Android450 , May 22, 2017 :
    I've had that off and if aggressive doze optimizes apps they will not give you notifications either on time or at all.
    Heisenberg_009 likes this.
  5. hedwigy
    Eclair May 22, 2017
    oh IDK coz I always get notifications with all apps optimized
  6. Android450
    Then you're lucky lol
  7. aryansaxena
    Cupcake May 22, 2017
    aryansaxena , May 22, 2017 :
    It does happen. I'm an Instagram user as well. And my phone kills the app in the background, which is why it is not able to send any notifications.
  8. Android450
    Read the replies above you....
  9. Abhishek4441
    Froyo May 22, 2017
    Abhishek4441 , May 22, 2017 :
    where to auto launch in settings Buddy?
  10. r.ram8
    Eclair May 22, 2017
    r.ram8 , May 22, 2017 :
    In your app settings, look for the COGWHEEL at the upper right corner, tap it then at the bottom of the list you'll see it.
  11. fdz_alicia
    fdz_alicia , May 22, 2017 :
    My OnePlus 3T just went silent for no reason. Still media, but no notifications or alarms at all. Please help!
  12. Abhishek4441
    Froyo May 22, 2017
    still I'm not getting notifications from Instagram bro
  13. Arun Sharma
    Gingerbread May 22, 2017
    Arun Sharma , May 22, 2017 :
    Try this Settings— advance— recent apps clear all mode— this should be normal clear.
  14. Abhishek4441
    Froyo May 22, 2017
    thanks buddy it's working
    Arun Sharma likes this.
  15. F1592744942657
    Cupcake Dec 5, 2021
