Notification shade is too large?
  1. YonatanM
    Cupcake Apr 28, 2018
    YonatanM , Apr 28, 2018 :
    After upgrading to 8.1, it has those large gaps between the clock and the quick settings. Is it like that for everyone?
  2. Wilhelm3108
    Waveform Modifier likes this.
  3. MentalDraco
    Marshmallow Apr 28, 2018
    Shubham Gujjar likes this.
  4. DanCtoo
    Honeycomb Apr 28, 2018
  5. Sarthakjain21
  6. Deactivated User
    Apr 28, 2018
  7. the_o2
    OnePlus 9 Series Expert Community Expert Apr 28, 2018
    sharks016 likes this.
  8. haro94
    Gingerbread Apr 28, 2018
    haro94 , Apr 28, 2018 :
    Is that achieved through theme-ing?
    Yeh same with mine, is this actually a 'feature' of sorts?! if so, im downgrading back to oos5
  9. MentalDraco
    MentalDraco , Apr 28, 2018 :
    Ozone / Substratum
  10. Mr_Cyrox
    KitKat Apr 28, 2018
  11. MentalDraco
  12. Mr_Cyrox
    KitKat Apr 28, 2018
    MentalDraco likes this.
  13. N1516855723481
    Eclair Apr 28, 2018
  14. Mr_Cyrox
    KitKat Apr 28, 2018
    Mr_Cyrox , Apr 28, 2018 :
    wow looks better then ever :D
    thanks!
  15. MentalDraco
    Mr_Cyrox likes this.
  16. Mr_Cyrox
    KitKat Apr 28, 2018
    lol didn't even notice XD
  17. haro94
    clearly, from the (suggested) fix, there exists excess padding - which may (1) bother a few people and (2) pretty sure no UI/UX designer does that on purpose.
    just highlighting a UI/UX issue.
    meh i assume that requires rooting and xposed of sorts. trying to keep my android native here xD
    but o well.. saw a post about this on reddit only after i pressed update; also kinda lazy to flash downwards..
    hmmmmm shall weigh my options. Thanks!
    EDIT: o wait i found an xda-thread that had a post about a rootless approach using the same tool.
    not to get my own hopes up but editing systemUI and making it survive reboots prob still needs root privis
  18. Divakar_Reddy
    Eclair Apr 28, 2018
  19. MentalDraco
    Nop :3 just install, hit build and reboot, no root, no sweat, no nothing :3 (well there are a few more steps but no root or anithing needed it's super easy AND there are a TON on customization available in substratum)
  20. MentalDraco
    here are some other fun things you can do
    1. Black instagram :3
    2. Black youtube
    3. Transparent shelf
    4. Black play store
    - Yea I know I like black - but there a ton more black, colored and transparent options, as well as system tweaks. (like an experimental always on display mode :3 )
