Notification slider hard to use and creaky
  1. Luk_
    Cupcake Jul 20, 2019
    Luk_ , Jul 20, 2019 :
    Hi !
    So, since 2 or 3 days, i noticed that my notification slider was very hard to use (i have a case with a extrusion for the slider and it is pretty hard, but when i take the case off, the slider is just impossible to use without using the nail.
    Plus, i noticed that the slider is creaky, and it is pretty disapointing.
    I don't know, i saw nobody with the same issue on the forum, is it possible to fix that ? Or it will fix itself with time, it's really weird.
  2. bonden_91
    Gingerbread Jul 20, 2019
    bonden_91 , Jul 20, 2019 :
    Well i have a problem where it works good when i put it on ring and vibrate but when i turn it på no notification(dont know exactly what it is called in english but when the phone is completely silent) it doesnt work and is very hard.. if i trix a little whit the slider it works but only after sometimes 5 minutes. Very frustrating..
  3. tonarmshq
    Eclair Jul 30, 2019
    tonarmshq , Jul 30, 2019 :
    Please look for dust ... :eek: I had the same issue and there was dust on one side, so that I couldn´t activate upto "mute" setting. I simply peeled it out with a thin tool and it worked perfectly again. :p
