Notification sound issue after oreo update
  1. F_Sanjay_Kukreja_WOzQ
    Donut Dec 21, 2017
    F_Sanjay_Kukreja_WOzQ , Dec 21, 2017 :
    Notification sounds now ring twice for a few apps, am noticing this issue after Oreo update, is anyone else also facing this problem ? if yes pls update if there is any solution for the same.
    thanks.
    amer nabeel likes this.
  2. F_Sanjay_Kukreja_WOzQ
    Donut Dec 26, 2017
  3. bwherder
    Cupcake Jan 5, 2018
    bwherder , Jan 5, 2018 :
    I am having the same issue and hoped that it would have been solved with the first update, but that didn't pan out. Although it happens with many apps, I also notice that a short time after DND is turned off there is a bunch of notifications the repeat as though they are in hold and likely still repeat each of them. Would love a solution.
  4. mgveld
    Cupcake Jan 29, 2018
    mgveld , Jan 29, 2018 :
    I'm having the same issue after Oreo update. After turning off DND I'm always welcomed by repeated notification sounds for about 15 seconds.
  5. G1517229655614
  6. raptor321
    Donut Jan 29, 2018
  7. TheDopeOn
    Donut Feb 9, 2018
    TheDopeOn , Feb 9, 2018 :
    Seems like a bug as of now. I'm having the same issues with my device (5T). Mostly happens in outlook app.
  8. Vinit Dedhia
    Eclair Feb 10, 2018
    Vinit Dedhia , Feb 10, 2018 :
    Same issue in my device with only outlook app..
    Reported the bug in forum but haven't got any solution for this..
    Everyone should do the same, maybe then they would know and give us a solution faster..
  9. Chinoman10
    Cupcake Apr 14, 2018
    Chinoman10 , Apr 14, 2018 :
    14th of April, problem still isn't fixed.
    I'd thought that One+ would've fixed this after a month of complaints from many users...
    PS: One+ 3 user here.
    PPS: Found this thread via Google.
