Notification sound unknown One Plus Nord with default launcher via OnePlus Nord
  1. Z1594630907247
    Cupcake Aug 10, 2020
    Z1594630907247 , via OnePlus Nord , Aug 10, 2020 :
    I hear a notification sound way too often and it disrupts even during calls so I can't heat the person I speak to and they cannot hear me. The sound breaks the audio completely.
    I cannot trace the sound to anything being logged in the notification settings menu, not even when showing system apps.
    I suspect it may be one of my apps but I'm not sure. I had a Pixel 2 before this phone and it never happened on that. I use the same apps as I did on that. Much fever actually. And I set up this phone from scratch with all the settings and apps.
    Please advice on how to proceed troubleshooting this.
    Thanks!
    Best regards,
    Sebastian Bergstroem
  2. L1597136253201
    Cupcake Aug 11, 2020
    L1597136253201 , Aug 11, 2020 :
    I have the same problem and it's quiet annoying, I even get the notification sounds when I'm watching YouTube and no notifications happening... Gonna remove the sound to see if that does it for the time being.
  3. Z1594630907247
    Z1594630907247 , via OnePlus Nord , Aug 11, 2020 :
    Please let me know if that helps. Most annoying for me is definitively that it happens during calls so I cannot hear the person I'm speaking to and they can not hear me. Anyone else with a similar problem?
    B1592488079916 likes this.
  4. A1597300840397
    Cupcake Sep 21, 2020
  5. Shiva090
    Cupcake Sep 27, 2020
  6. TMDMOOSA
    Eclair Oct 5, 2020
    TMDMOOSA , via OnePlus 8 Pro , Oct 5, 2020 :
    Same Problem in OnePlus 8 Pro Getting 2 to 3 times Daily irritating beep notification sound .I have used many mobile from Iphone to redmi low to high end .
    But this first time I'm purchase OnePlus but No volte and %G working and now this notification beep sound.
    Worst customer services.
  7. mittalsaheb23
    Eclair Dec 17, 2020
    mittalsaheb23 , Dec 17, 2020 :
    from last 2 days I am having same problem .an unknown notification sound is coming ,I checked last three app but it's not from them.
  8. B1612765964867
    Cupcake Feb 10, 2021
    B1612765964867 , Feb 10, 2021 :
    SOLVED
    I had this problem,
    I had cards with NFC in them and my phone came with it turned on from factory.
    TURN NFC OFF AND IT WONT TRY TO READ THE CARDS AND MAKE THAT ANNOYING CONSTANT SOUND.
    Hope this helps :)
