notification sound
  1. amitsingh1
    Cupcake Sep 18, 2019
    amitsingh1 , Sep 18, 2019 :
    My phone makes notification sound even when there is no notification. It's irritating. Are there any solutions?
  2. teachmeluv
    Eclair Sep 19, 2019
    teachmeluv , Sep 19, 2019 :
    Something must happen on the phone when a sound is playing so please more detail. What ROM are you using? Have you tried clean/wipe cache and restart?
  3. amitsingh1
    Cupcake Sep 19, 2019
    amitsingh1 , Sep 19, 2019 :
    teachmeluv
    Something must happen on the phone when a sound is playing so please more detail. What ROM are you using? Have you tried clean/wipe cache and restart?​
    What catche? How to wipe? I don't know about ROM.
  4. drl431
    Lollipop Sep 19, 2019
    drl431 , Sep 19, 2019 :
    Disable each app you have installed, one at a time, until the problem goes away. Then uninstall or change settings for the problem app.
  5. amitsingh1
    How can i know which app is causing problem?
  6. drl431
    Disable each app one at a time, or just uninstall the junk apps.
  7. amitsingh1
    Okay.
    drl431 likes this.
