Notification sound via OnePlus 8 Pro
  1. S1549657263584
    Cupcake Dec 4, 2021
    S1549657263584 , via OnePlus 8 Pro , Dec 4, 2021 :
    Hi. Oneplus 8 pro. There's a problem with the notification sound. It is not possible to change the sms sound independently to the default notification sound. Please fix this issue. Thanks.
  2. Aaron2017
    General Support Expert Award 2021 Dec 4, 2021
    Aaron2017 , Dec 4, 2021 :
    This is a user forum, only users are here, nobody from OnePlus. But you can set a different sound for messages (or any other app). Long press on the message app>notifications>standard (that's what it says in my language, it may be different for you)>advanced>sound and set the notification tone you want.
  3. S1549657263584
    Cupcake Dec 4, 2021
  4. Aaron2017
    If you long press on the message app>notifications, do you see any options under "conversations"? Could be individual contacts or a general option or something. I have the 8 pro as well and i have that option. Just to check, you use OnePlus' message app right?
    Caomhin and Shailender Sharma like this.
  5. S1549657263584
    Cupcake Dec 4, 2021
  6. Aaron2017
    I'll add some screenshots how it is on my phone, so first long press on the message app itself and press app info and you should get the following screen
    Then click on notifications and you should get the following screen with the "conversations" section
    There, below where it says "other", you should be able to scroll down to find, in my case here, some individual contacts option (where i can set a different sound for each of those contacts) and a "standard" option too to change the notification tone for all incoming messages
  7. S1549657263584
    Cupcake Dec 4, 2021
  8. Aaron2017
    Go to the settings in this screenshot you took
    And click on "default" (i marked it), there you should see the "advanced" setting, click on it and there you should see the "sound" option to change the notification sound to the one you want
  9. S1549657263584
    Cupcake Dec 4, 2021
  10. Aaron2017
    Oh really? Because there's a little line, like this "|" just before the toggle to turn it on/off, which would indicate there are more settings under that tab. Just to check, you clicked on the word "default"? Not on the on/off toggle, that doesn't give those extra settings
  11. S1549657263584
    Cupcake Dec 4, 2021
    You are correct. If I click on default it gives more options. Changing the sound is an option. But no matter what I change it to the sms notification still comes out unchanged. It, and indeed all notification sounds come out as set under the sound settings in the main menu.
    Once again thanks for the help.
  12. Aaron2017
    You're right, i never changed that sound because i use Google messages mostly, but changing the sound there doesn't make a difference. Well, then it's not possible with the stock message app. You can, if you don't mind using Google messages instead of OnePlus' message app, change it to a different with Google's message app. That's what i did and it works, i have a different notification sound then the one that's set as default
  13. S1549657263584
    Cupcake Dec 4, 2021
    Thanks for helping me out with this issue.
    So I'm not totally inept 😂
    How do you like the Google message app. What are the pros and cons versus the stock app?
    Obviously being able to change the notification sound is a plus.
  14. Aaron2017
    You're welcome.👍 Well, it's mostly personal preference, i always used it when i had both Google's pixel phone, where it was the default app anyway, and Samsung phones because i didn't like Samsung's app. But Google messages has the RCS chat feature, that's about the same as iMessage on iphone's, and i just like the way it looks. There's also the scheduled message option, which can come in quite handy, and of course changing the notification sound.
  15. S1549657263584
    Cupcake Dec 4, 2021
  16. Aaron2017
    No worries. Yeah, if you don't like it, uninstall it and it'll be like nothing happened.😉 Yeah, indeed, you take care and stay safe yourself too.
